front tie rod torque spec?
Here's what I show.
STEERING
Inner Tie Rod 100 N·m 74 lb ft
Outer Tie Rod End Stud Nut to Knuckle
First Pass 20 N·m 15 lb ft
Second Pass 160 degrees
Final Pass 45 N·m 33 lb ft
REAR SUSP
Final Pass 60 N·m 45 lb ft
STEERING
REAR SUSP
Forum member David Farmer has a great website with a link to his torque spec files with just about every torque spec you'll ever need:
http://davidfarmerstuff.com
I assume you're talking about the jam nut and the spec to torque it down after adjusting toe.
On David's site it says:
HOWEVER.....I just did some work on the front today to get my steering wheel straight. I don't have a torque wrench that will fit on a nut with a tie rod going through it, so I just snugged the jam nuts down good with my calibrated wrist!!
Bob
Steering
Adjuster Plug Lock Nut 68 N·m 50 lb ft
Rear Suspension
Adjustment Link to xmember Nut 60 N·m 44 lb ft
I confirmed that in my 2006 Shop Manual and it says the front jam nut is 50 lb ft, and the rear jam nut is 44 lb ft.Adjuster Plug Lock Nut 68 N·m 50 lb ft
Rear Suspension
Bob
