What is the best aftermarket intake system for an LS2?
I'm looking for highest performance increase and no decrease in bottom end power.
I wanted to get the Bee Hive 2, but it isn't for an LS2.
- The intake filter system having a heat sheild protecting it from the engine bay with the filter down below and the dyno numbers are great is why.
I also was considering one of the Intakes that has a ram air duct going to the hole in the front bumper.
http://store.corvetteforum.com/p-138...0-non-z06.aspx
Does this outperform ones without a ram air setup?
Also is this intake "Hurricane" designed the same way, and does it perform better or worse than the Vararam intake?
http://store.corvetteforum.com/p-384...07-c6-ls2.aspx
aka is it worth the extra $50 over the Vararam intake?
if so is it also worth an extra $300 ($584) for the carbon fiber version?
Consider the above two kits are cheaper or the same price as a K&N Intake and seem to be more advance, whether I should get one of them instead of a trusty K&N intake kit.
** And is the K&N really outperforming similar systems that cost less?
Otherwise if a drop in K&N will provide some power boost I'll just do that, but I'd really like to maximize intake ability.
** So which intake system performs the best without being additionally expensive compared to others? or are they all the same.
I know lots of questions!!
I was going to get a K&N or BBK intake locally, but notice for the same price or less I could order kits that seem more advance. Question is are they really better?
*Last question: If I do just get a simple trusty K&N or BBK dual filter intake, is there a Bee Hive 2 style cover that would shield and separate the engine from the intake filter and improve performance sold separate of the Bee Hive 2 kit?
EDIT:
New Question... are all the kits the same performace wise? or at least are all the simple intake kits (non ram air) the same? If so would a $219 Airaid kit perform the same as the $400 K&N kit. If so for $220 I have nothing to loose getting this kit...
http://www.stage3motorsports.com/c=q...ntake-Kit.html
EDIT:
They all post similar dyno gains. The vararam is crap and has more than its fair share of fitment issues. I had one I know from experience. The ram air is nice but it doesnt really work unless your hauling butt already. I personally went with the halltech with the cold air mod and the beehive shroud. It will fit your LS2 the shroud is the exact same on the LS2 as it is on the LS3 Ive installed one on both types of engine.
I have to disagree here too. I posted almost the same time with my halltech as I did with my vararam. The D/A was similar within a few hundred feet (it very very rarely goes below 1000 here) and so was the temp. The et was less than one tenth apart.
didnt you have a problem with yours sealing
It is generally accepted that a stock Chevrolet Cobalt SS cannot beat a stock Corvette Z06 yet I've seen it happen.
In a controlled environment with all else being equal (though all else is so rarely ever truly equal) a properly installed Vararam will outperform (ET and trap speed) every other cold air intake on the drag strip.
Some of the others are also good and they too WILL improve performance as well of course but I believe that the original poster is seeking an absolute best possible results scenario:
******RETIRED ARMY******
St. Jude Donor '12
So I looked at your profile and there are no mentioning of any other MODS for this, to get a true stattement of what you are asking for I would believe that people would need to know if you had headers, X-Pipe cats or not, different over the axle exhaust, has the car been tuned?
Just adding a CAI will really do what because if you don't have the access to get the flow completely through then what really have you gained. Surely not enough HP for any noticable increase.
1. The Killer Bee and Bee Hive will work. You have to do something with the MAF. Halltech can help you with that problem.
2. I'm not a big believer in the 'ram air' stuff. There seems to be some quaility problems sometimes, also.
3. Any true CAI gets cold air to your intake while usually keeping the engine heat away.
The carbon fiber piece will not make you go any faster.
4 Most all CAI use a K&N type filter. Is this K&N a true cold air intake, of just a different filter? You don't have to believe all the HP claims.
5 I did the Killer B...B hive, and Vette Air for cool air.
6 You will get a half dozen answers on which is the best one. I gave you my choice on #5
7 Yes you can buy the Beehive alone.
8 If I remember correctly the Ariad is a CAI. I don't know about the K&N. Just changing the filter and not getting fresh air is a waste to me, but a lot of guys do it. Is a it worth a $200 differance between the two.....NO.
One more thing.....don't expect much. I understand the LS2's intakes suck(yea..I know they all do), but the LS3 and 7's have good ones to start with. A filter on these that give you 20% more air... when the stock filter gives you 20% more than you need. Makes you wonder why you would need it....unless it's dirty.
Of course....these are just my opinions.
Larry
Larry
This has already been proven quite a few times in the past.
2-3 tenths may not sound like much but in drag racing it's practically an eternity.
Larry
Larry
SUBVETTE
An intake by itself isn't going to do much for you at all. it should be part of a more comprehensive package (such as ported throttle body / ported intake, lower temp thermostat, headers, exhaust system, tune, etc). Think through what your goal is and then assemble the package of mods to get there. That being said, are you going to run the car at the strip? If not, ram air type intakes will not give you much advantage at normal driving speeds. I had a Vortex Ram Air on my LS2 which on the dyno showed lower results than with a K&N, so I removed the Vortex and went with the K&N. I don't take this car to the strip, so I get all the performance I want from the K&N on my car. With regard to intake temp differences betweeen "outside air" intakes and intakes that breathe air in the engine side of the shroud, I did my own experiment using remote temp sensors at the intake to my K&N (Inside the shroud) as well as outside the shroud (in the radiator cavity where my previous cut shroud Vortex had breathed) and found only a two to three degree difference under most all driving conditions. So timing isn't going to be pulled just due to where the air is breathed by your intake.
Bottom line: If all you are going to do is slap a different intake on, don't waste your money.
