2005 to 2008 Steering Wheel Swap
Was the 2005 steering wheel used on any other GM car?
If so, could the 2005 airbag/cover be replaced by a part from a GM something, just lacking the Corvette logo? Parts commonality is pretty common among GM cars. Thanks for any suggestions.
No imposition intended. It was a question for the many forum experts that have a lot more experience with Corvettes and GM cars than I do. The 2005 DS airbag is nearly impossible to obtain. Thanks much to anyone who might know about this.
Received 1,194 Likes
St. Jude Donor '15
I thought there was a Pontiac G6 or G8 that used a very similar steering wheel
Whether they are exactly the same or not (logo aside), I was never able to figure out. I was going to try one to find out if I could find one cheap enough, but never could
I finally broke down and just bought a Corvette airbag when I did my steering wheel retrofit.
http://www.s10forum.com/forum/f178/c...airbag-514382/
And I've searched but none of the earlier GM doughboy steering wheels are a match for the 2005 Corvette. It does appear to be one-of-a-kind, and no longer available from GM. I'm surprised since GM loves to share parts between platforms. Was just hoping...
I found this.... Pontiac Solstice Saturn Sky Opel GT Steering Wheel 25864147. Just for future references.
http://www.ebay.com/itm/Pontiac-Sols...225d3c&vxp=mtr
St. Jude Donor '15
Buttons are totally different.. though it would be nice to have cruise control on the steering wheel
i have an 05 ds airbag from my steering wheel swap. if you are intetested pm me.
Okay...But what about switching from a later model back to the '05 wheel. I really like the looks personally of the '05 wheel--just seems a little more Corvette specific. But has anyone gone from a later wheel/model back to an '05 ? The last Vette I owned was an '04 12 years ago...Getting ready to re-join the life!!! I'm debating between two Vettes right now--one's an '07 and the other an '08. Love the looks of all the C6's, but just prefer the '05 wheel...Any info/experience anyone has on switching back the other way?
BTW, there are probably some who may be willing to do an even trade of their 3 spoke with your 4 spoke with all the hardware involved. the 4 spoke is a nice steering wheel too.
#33
St. Jude Donor '15
Yeah, plenty would gladly trade you their 05 wheel for a new one.. the airbags are a bit more expensive on the later ones (ask me how I know!) so you could come out a bit ahead if you wanted
I put a later model wheel on mine a while back so I'm going from memory here, but from what I recall the airbag connectors were exactly the same, so those will work no problem
All of the wiring for lights and steering wheel buttons won't matter since you won't be using it on the new steering wheel. I can't recall if the connector for the horn is the same or not though.. worst case you'd probably be best to swap a wheel, airbag, clock spring and connectors for the horn/light/buttons with someone who wants to get rid of their 05 setup. You may have to move a wire or two around to make the horn work but that'd be about it.
It should be a very simple install going to an '05 wheel.
#34
I did the 05 DS wheel on my 05 and had a heck of a time removing the air bag until I realized the 05 has 4 holes to push the spring clips away from the air bag hooks. After that, the rest of the install was a breeze. One other thing is the 05 wheel modification on the bottom being flattened out takes some getting used to. May want to see if you can get this step deleted.
