How to replace a fuel pump
Old 11-14-2015, 07:58 AM
  #181
hamster37
hamster37's Avatar
Originally Posted by bonecrrusher
Good afternoon,
I got my drivers side tank out last night - and snapped the fuel return lines inside the tank.
I already have the replacement parts coming from Amazon.
I had a question on the plastic sleeve gasket.
The smaller one is still in the cross over tube - and is on top.
The larger one one bottom is loose - and looks like it might have a rubber o-ring grove formed into it.
I looked around and did not see any random loose o-rings on the floor, in the tank, or on the car.
Did I lose an O-ring on that sleeve?
Yes.
If you try to plug the coupling you pictured into the tubes inside the crossover pipe, you'll notice that the one without an o-ring is loose.
The part you ordered on Amazon should come with new o-rings (they aren't included with the crossover pipe and they aren't sold separately, so they have to come with the fuel return line.)
BTW, take a small mirror and inspect the open end of the crossover pipe. If your plastics are starting to snap, you might already have damage to the male side of the plug and to the plastic insert around the mouth of the pipe.
Old 11-23-2015, 02:56 PM
  #182
bonecrrusher
bonecrrusher's Avatar
Good afternoon,
I got the old fuel pump out and noticed my Fuel Level sensor was gong bad - so I ordered a new one.
I was expecting some instructions with the new one - but got nothing.
Does anyone have a wiring diagram for the 2 green lines that go into the harness that plugs into the fuel pump?
I already depinned the OEM Fuel Level sensor - and should have taken pics - but I didn't.
I want to make sure they end up in the correct slots in the plastic fitting.
Thanks.
Old 11-27-2015, 07:35 AM
  #183
cormudd
cormudd's Avatar
Originally Posted by Bill Curlee
You tell me what part of the frame that you would safely cut to get the pump out??????
This is a C6 ZO6 frame but,,, its NO different than a steel C5 Frame. As you can see,, the metal channel that runs across the car blocks the top of the pump assembly let alone all the SMC body structure that you would have to destroy.
Theres NO WAY,,, your going to be able to TILT that pump body to get it out from under that beam.. Its tough enough to get it out when the tank is all the way out.
BC
Its not about getting the pumps out, it's about disconnecting the cross over tube.
Old 11-27-2015, 07:36 AM
  #184
cormudd
cormudd's Avatar
Which you can see this guy did the same thing I did basically
Old 12-04-2015, 07:51 PM
  #185
martysauto
martysauto's Avatar
St. Jude Donor '14
Thanks Motörhead! Great write up and pictures. Your post was a big help when I replaced my leaking pump module.
Old 03-10-2016, 01:32 PM
  #186
mracer
mracer's Avatar
Big Kudoo's to Motorhead-47 for a great write up! Posted a link to this thread in the sticky "Danger Fuel leaks" over in the General C6 section!
Mike
Old 10-21-2016, 10:51 PM
  #187
taxmannv
3rd Gear
taxmannv's Avatar
Hard part of this job is disconnecting and reconnecting the crossover tube. After a couple of hours of frustration of trying to do a blind job from below, I simply cut a hole from above. Suddenly the job was super easy. disconnecting and reconnecting the crossover tube was a snap and took about 10 minutes each. Resealing the hole was also easy since I had simply bent auto body parts back for access and to reseal I bent back and sealed it with appropriate tape. I have pictures if anyone is interested in this technique. I never had to drop the exhaust or drop the differential and wheels. total job took about three hours.
Old 10-22-2016, 08:10 AM
  #188
GeneSch
GeneSch's Avatar
Post up your pics.
Old 10-26-2016, 09:22 PM
  #189
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by GeneSch
Post up your pics.
I AGREE!!!!!!!!!
Old 11-01-2016, 03:56 AM
  #190
DMONSVETTE
DMONSVETTE's Avatar
This is the BEST write up with excellent pics that I have EVER seen.
Thanking you ahead of time because sooner or later.........
Old 01-18-2017, 10:49 AM
  #191
roger55
roger55's Avatar
It looks like the Delphi FG1092 left tank fuel pump for 2007-13 Corvettes is finally back in stock again at some parts houses. This had been out of stock everywhere for quite some time.
I'm wondering if this is the brand Chevy dealers are using and if it's the one that should be an improved version that wont crack at the top connection.
My '08 has a gas smell and I'm reluctant to take it to a dealer to get fixed. Even though they may cover the expense, I'm worried that they will break the tank or just mess it up somehow.
With the fine write-up and photos at the beginning of this thread, I have no qualms about doing the job myself. However, I do want to make sure I'm using the best made part available.
Old 02-15-2017, 08:22 PM
  #192
cwylie
cwylie's Avatar
So got the tank out today with the help of your instructions but it looks like I broke a piece in the process. Anyone know what the part number is for this part?
Old 02-15-2017, 08:42 PM
  #193
roger55
roger55's Avatar
I just finished replacing my pump a couple of days ago. I broke that too. It was stuck on the mating tube so bad, there was no way it could have not broken those tabs.
I bought my replacement on Amazon:
https://www.amazon.com/gp/product/B010GMIUBC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B010GMIUBC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Old 02-15-2017, 09:12 PM
  #194
cwylie
cwylie's Avatar
Ouch. $75! Anyone have the GM part number by chance? I might have to pick it up at the dealer to save some time.
Old 02-15-2017, 09:21 PM
  #195
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
It's on that page...
10337583
Old 02-15-2017, 09:52 PM
  #196
Motorhead-47
Motorhead-47's Avatar
http://www.gmpartsdirect.com/auto-pa...omponents-scat
Old 02-16-2017, 09:29 AM
  #197
roger55
roger55's Avatar
So as I said earlier in this thread, I decided to do this job myself rather than to trust a dealer to do it. Even though it cost me $215 to buy the Delphi fuel pump module. My 2008 has a manual transmission.
My job is finished. My special thanks to Motorhead-47 for photo documenting the job in this thread. It was a tremendous help.
I did have a couple of complications. First, I had to break the auxiliary fuel feed/return pipe tubes because the connection was stuck badly at the end of the large metal crossover tube. I had to pry on it to get it to come off and even that wasn't easy as it was stuck so bad. So it cost me an extra $69 to replace that auxiliary tube assembly. So total cost came to $284.
I had another issue too. After reinstalling the tank and trying it out, it ran fine but my gas gauge didn't work. It also got a "service fuel system" warning.
I traced it down to an open reading across the wires to the sending unit. I pulled the tank again and then pulled the fuel pump module. Evidently, I got the float hung up on one of the auxiliary tubes.
I very carefully reinstalled the module and made sure I didn't have any hang up this time.
It's all back together now and works perfectly. Sure is going to be nice not to have the stink of old gas in the garage anymore.
To How to replace a fuel pump
Old 02-20-2017, 11:08 AM
  #198
cwylie
cwylie's Avatar
When you guys reinforce the clips with JB weld are you pretty much just gluing the tubes in place in the tank?
Old 02-20-2017, 11:31 AM
  #199
roger55
roger55's Avatar
No glue is used for this job.
Besides, epoxy will not hold up in gasoline with ethanol.
Old 02-20-2017, 11:53 AM
  #200
cwylie
cwylie's Avatar
Well do you use JB Weld to essentially glue that clip in place?
Quick Reply: How to replace a fuel pump
