C6 Tire Ratio FR/RR
C6 Tire Ratio FR/RR
Looking to buy new tires for 08 LT2 (18x8.5) & (19x10). Stock is 245/40-18 (25.7) Rear is 285/35-19 (26.9). Wanting to put on 255/40-18 (25.9) and 305/30-19 (26.2). Wheel height difference is Fr (.2), Rr (.7). Will this screw with traction control with a rear to front difference of 1/2 inch? Rather have more sidewall for the rear though. Any suggestions on "affordable" tires for a DD?
Options
Understood and have checked the website previously. I was looking at the Nitto Invos with the larger sizes for my new rims. I was wondering about other options in those sizes and the discrepancy of the ratio between OEM tire height and the stated size wanted.
Ratio
I took 4.5% median and applied to tire heigth. OEM comes out almost exat with front vs rear. Sor a 305 I need to find a 305/35 or 27" rear tire to keep 255.
Nice
If your playing with sizes this might help http://1010tires.com/TireSizeCalculator.asp
I remember reading a thread where this was discussed -
http://forums.corvetteforum.com/c6-f...d-upfront.html
Powerlabs (post #15) made mention that the BCM requires no more than +/- 3% size difference in diameter to the factory sizes.
Track Junky
275/35/18 and 305/30/19 on stock rims here. Thats about 0.7" difference in diamater. Only run into computer issues on the road course above 90 mph.
265/35/18 and 305/30/19 has proven to work just fine on the street and the track. This maintains anout 1.0" diameter difference.
If the computer sees anything much different than the expected 1.1-1.2" diameter difference, you could have issues at higher speeds.
Diameter is just one consideration for a tire size change.
The 245mm front tire on a 8.5" wide wheel is correct, a 275mm tire on a 8.5" is not correct.
The 285MM rear tire on a 10.0" wheel is correct, the 305mm tire on a 10.0" wheel is not correct.
You are losing sidewall support and affecting handling by going a wider tire on a narrow wheel.
Track Junky
In addition, you can definately feel sidewall flex in the 275-305's but again, that could be the fact that they are not runflats (much thicker sidewall). Haven't run 255's or 295's yet, but plan on swapping to 265/305 for my next set of tires.
I have only run Homestead Motor Speedway. The 275/305 PS2 combo is running 6-7 sec faster than my 245/285 Wide Oval runflats. Now some of that is tread rating, but I don't believe it's all of it.
Track Junky
Track Junky
Good info here...helping as my rear tires will need to be replaced in the next 1-2 months. Replacing the stock sized Invo's with something a little wider is exactly what I would like to do but my front tires probably have another 10k left in them..
