Lowering C-6 Z06 With Stock Bolts
I'd like to lower my 2008 Z06 using the stock lowering bolts. How much lowering height can I expect using the stock lowering bolts? Thanks for your replies.
Marc
Bend, Oregon
2008 JSB Z06
msschafler@gmail.com
Marc
Bend, Oregon
2008 JSB Z06
Marc
Bend, Oregon
2008 JSB Z06
Marc
Bend, Oregon
2008 JSB Z06
I've never seen a C6 of any kind get anywhere near 1" of lowering without cutting the bushings.
I have had 4 C6's including one Z06. The rears I've seen are the problem. About 1/4" on the rear is all I've seen and about 3/4" on the front.
I have a 2011 grand sport. The right rear bolt turned 1 1/2 turns. The left rear bolt turned 1/2 turn. Both bolts were maxed out. That equates to about 1/32".
The 2009 Z06 I had only lowered 3/8" in the back. Front could have gone a little lower than that.
i just went as low as i could in the front with the stock ones, and in the rear i bought some rubber bushings off ebay that allow you to remove the stock bolts cut off the old 1'' thick bushing and replace with the 1/4'' ones. then set those as low as possible. looks perfect i have just over a fingers gap between tire and fender. never actually measured it looks great though and not so low i drag on everything well the plastic air dam does but it did before.
AutoX Central Oregon
Hey Marc,
Bring that Z06 up to Hoodoo and let's race! Details on upcoming events at http://www.autoxclub.org/ and our Facebook site at http://www.facebook.com/group.php?gid=73528508958
I'm also a member of High Desert Corvettes, but it all social clubbing, not racing. http://www.highdesertcorvettes.com/
