E-Force Supercharger Dry Sump Installation
Old 01-15-2011, 12:36 PM
PureAdrenaline
PureAdrenaline's Avatar
Default E-Force Supercharger Dry Sump Installation
I have a 2010 Grand Sport manual with the dry sump. Has anybody installed either kit on the dry sump car??? What is needed extra to complete the installation?? Thanks.
Clay
Old 01-15-2011, 12:45 PM
m R g S r
m R g S r's Avatar
there have been a few others installed on grand sports. i dont know if anything else was needed to do it, but i would assume no.
Old 01-15-2011, 12:50 PM
PureAdrenaline
The dry sump requires some extra work. I am trying to find out what is involved.
Old 01-15-2011, 11:19 PM
geewez
geewez's Avatar
I was down at TPS ( Campbell, CA) earlier this week and they told me that Edelbrock is modifying the kit to fit the Grand Sports and they'll be the first ones to try them. Give them a call.
Old 01-16-2011, 03:00 AM
m R g S r
m R g S r's Avatar
ohh i could be wrong then, but i could have sworn i saw more than 1 thread about Eforces being installed on 2010 GS's?
Old 01-16-2011, 05:29 AM
tonypittman
Support Corvetteforum!
tonypittman's Avatar
It's certainly been done. Saw a GS Convertible with one on it at a drag event at Texas Motor Speedway. LG Motorsports did the install. Maybe check with them.
Old 01-16-2011, 07:05 AM
Motorhead-47
Motorhead-47's Avatar
Edelbrock has not released the kit yet for the LS3/LS7 dry sump motors. It is due out in Feb.
Old 01-16-2011, 07:06 AM
Motorhead-47
Grand Sport convertibles don't get the dry sump motor.
Motorhead-47
They would have been Grand Sport Coupes with 6-speed auto transmission. Autos don't come with dry sump option.
Old 01-16-2011, 07:15 AM
Motorhead-47
Clay
The Grand Sport dry sump kit will be a different animal. The one obvious visual change is the passenger side coil cover will be different...no dipstick tube hole, your crankcase ventilation is different necessitating a different valley pan and associated plumbing for it and the biggest change is going to be the fact that your dry sump motor has the Z06 oil cooler up front. That cooler will have to go as it offloads too much heat into the supercharger heat exchanger. The last I heard the plan was to use the ZR1's fluid-to-fluid oil cooler but I haven't seen it yet.
Straight from Edelbrock's tech forum....
Hello,
The dry sump accesory kit will include the following:
-New valley plate with PCV fitting for dry sump
-Proper crank pulley bolt and drill fixture bolt for dry sump
-Different PCV lines to route to dry sump tank
-ZR1 liquid to Liquid oil cooler to replace air to oil cooler, which
compromises performance of intercooler
-RH coil cover, without dipstick hole
-Rob
Old 01-16-2011, 02:42 PM
PureAdrenaline
Hello,
-Rob
Thanks Rob. The best info I have seen yet. Looks like a tried and true version will be a few months out if we are lucky. I may go another route.
Old 01-16-2011, 04:50 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I suspect that the GS dry sump version and the Z06/LS7 version will be released around the same time since once Edelbrock makes the changes to install a E-Force on a Z06 you should have the changes to mount the LS3 E-Force on a dry sump LS3. But, that's a guess on my part.
I understand the Z06/LS7 E-Force is ready to be released except for the completion of the tune. Since the tune on a regular LS3 should be the same as a dry sump LS3, I would think the unit would be ready for release any day now.
Old 01-16-2011, 05:26 PM
Motorhead-47
Old 01-16-2011, 05:30 PM
tonypittman
Sorry....my fault. It did not have dry sump.
Old 01-16-2011, 05:37 PM
Motorhead-47
The non dry sump LS3 Grand Sport uses the 1590 or 1591 Edelbrock E-Force kit.
Old 01-16-2011, 05:40 PM
Motorhead-47
One thing that no one has talked about yet is the inevitable fact that the addition of a ZR1 oil cooler setup is going to drive the price up on the dry sump E-Force...mo parts = mo money!
Old 01-16-2011, 08:14 PM
JoesC5
JoesC5's Avatar
And you know the Corvette tax on a GM ZR1 part is going to be steep.
To E-Force Supercharger Dry Sump Installation
Old 01-16-2011, 08:25 PM
Motorhead-47
The ZR1 cooler alone is about $450.00 at the forum parts vendors. Add in the lines/plumbing and I can see it driving up the price of the Dry Sump kit by maybe as much as a grand...ouch.
For those that haven't seen what a ZR1 oil cooler looks like here is one attached to the ZR1 pan.
Old 01-17-2011, 02:19 PM
0Steve@AandACorvette
Former Vendor
Steve@AandACorvette's Avatar
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Last I heard, this supplement kit was going to be around $1,200.
Old 02-17-2011, 05:30 PM
ITSGRAND
ITSGRAND's Avatar
It doesn't appear that a ZR1 oil cooler is being utilized. Here's the parts list I have "procured" from a distributor
Part # Qty. Description
22-1575 1 - Hose, Dry Sump to Air Inlet, Passenger Side
22-1576 1 - Hose, Dry Sump to Valve Covers
46-1503 2 - Clamp, Hose, 9/16" Wide, 1-5/16" to 2-1/4"
46-2164 2 - Hose Clamp, Constant Tension, For 5/8" Hose
46-6223 2 - Clamp, Hose, ¾”
51-4103 1 - Fitting, Water, ZR1 Oil Cooler GM# 2586-5738
88-0623BK* 1 - Fitting, -8 AN Swivel to 5/8” Barb, 90°
88-0621 1 Fitting, Adapter, 5/8” Hose to OEM Block Fitting
51-4104 1 - Tee, 1.3125” X 0.625” X 1.3125”, Nylon; GM# 9222-709
46-2161 .33’ - Convolute, 1” ID, Black (4”)
24-15913 1 Cover, Ignition Coils, Corvette, LS7, RH; 808 AL
(44-15907 casting)
24-15918 1 Valley Tray, LS7, (44-15908 casting)
51-7014 1 Fitting, Vent, 10mm, SAE Quick Connect, 90°
36-1518 2 - Bolt. Hex Flange. M8x1.25x30mm. CL 8.8, Zinc plated
36-4048 1 - Bolt, Cap Screw, M16 x 2.0 x 150mm, 40mm
thread,Standard Hex, 8.8
51-4109 1 - Bolt, OEM, Z06, Damper
24-4111 1 - Oil Cooler, Trimmed, LS3 Camaro
Quick Reply: E-Force Supercharger Dry Sump Installation
