Any California residents with Lingenfelter N/A setups?
1 Post
Hey guys, how's it going? New member here and this is my 1st question. I'm interested in either the Lingenfelter 630hp or 660hp N/A engine packages. But since I live in California I was wondering if either of these would pass CA smog testing? I emailed a Lingenfelter Rep and he said they had no N/A packages approved for sale in CA.
But I was also told by A&A that I could install a cam that would get me to 650hp that would pass CA smog testing. I would assume that both cams would be very similar and have similar exhaust output. I'm not very mechanically inclined so if I'm way off in my assumptions let me know. Hopefully there are some CA residents with these engine packages that can shed some light on this. Keeping this car registered is a must.
Car is 2007 Z06
Car is 2007 Z06
1 Post
Here are the specs on the two camshafts used in said engine packages:
LS1-GT19
duration: 227 / 239 @ .050
valve lift: .678" / .688"
rocker arm: 1.8 ration
centerline: 114
LS1-GT21
duration: 243 / 259 @ .050
valve lift: .691" / .702"
centerline: 112
Anyone successfully pass CA smog running similar cams or more aggressive cams?
LS1-GT19
centerline: 114
LS1-GT21
centerline: 112
I think those are both to big. I was under impression that for the LS3 a 224-228 was about it with a 114. Maybe 30 hp. No prof just from my research.
Even with the best tune in the world the GT-21 would never come close to passing Ca smog. The GT-19 could be tuned to pass the sniffer test. However, you would have to find a mod friendly smog place that is willing to ignore the massive lope coming from your ZO6. Which has gotten harder to do in recent years sine C.A.R.B. started cracking down on smog shops.
I run the GT-19 and don't think there is ANY way you are getting that one to pass. I run w/o cats ( because I can in teh county I live) and sometimes wish I took the time to install them during the off season.
I'f you want 650 hp, I AND pass emissions you may be looking at FI.
The GT-11 cam/ LPE heads have proven 500 RWHP on a LS3 or two locally..... and is barely noticeable.
1 Post
I'm having a hard time thinking you can go from 505 HP stock to 650 HP without headers and have a cam that is emissions friendly. That is a big gain and would require serious head work or more cubes. An A&A blower seems like the best solution for a do it once and not worry solution.
Ahem:
http://forums.corvetteforum.com/sout...ffer-test.html
Starting in 2013 any 2000 model year and up car no longer has to pass a sniffer test. Put whatever you want in it! Just find a "friendly" smog shop that isn't **** about the visual.
