Ls2 Valve Spring Specs
Hi all, I'm putting together a stock ls6 motor and I'm using the heads from an ls2 ( I know they dont have the sodium valves lol) anyway the spring on the heads are stock springs and they are stock machined steel in color and have a blue stripe going down the side I've seen this on quite a few stock ls2 heads. However are these the same spec springs as the yellow ls6 springs or are they weaker for the ls2 cam. I'm just wondering if I should go ahead and order a set of stock ls6 springs for the motor even though its only running the stock 02 on up ls6 cam or woudl the ls2 springs be fine since they are almost new?
Thanks Dan
Thanks Dan
I gotcha, I'm not sure what I want to do in the future yet so thats some food for thought but ya I wasnt sure since these are just a normal steel color if they were the same as the yellow beehives.
