The #'s they recommend did not fit. At least the A/C for sure, it's too wide and long. Haven't tried the main belt as of yet but when I return from the parts store I'll let you know what I came up with. Apparently others have had this issue, however, I've not seen the EXACT part numbers they used to correct the problem.
SLP UD pulley Main belt # ended up being 6PK1755, A/C belt was 4PK1010. Neither of the belts listed on the site were even remotely close. This was for a 2007 LS2.
Reason: Part #
