Russell C6/ZO6 Stainless Steel Braided Brake Line Kits Only $119.99 a set!!!The BEST
Former Vendor
Hey guys check this out, we have cut a deal with Edelbrock-Russell so we can provide the Best Brake Line Kits for Corvettes to the Corvette Forum Members
These lines have a Clear Teflon Coating over the stainless braided line.
New special price, these four line kits are only $119.99 a set.
Also dont forget about SPEED-BLEEDERs for your Calipers...they make bleeding much easier and a one-man job!!!
C6/Z06 Russell SPEED-BLEEDERS $19.99 per pair...
These are Not China made junky ones...
Direct bolt-on brake hoses bring the ultimate in braking performance.
Replacing OE rubber hoses with Russell brake hoses reduce expansion for improved braking and firmer pedal feel.
Factory assembled for an easy installation, these hoses feature stainless steel braided hose with zinc-plated fittings.
Meet the guidelines of the U.S. Department of transportation(mrss-571.106)
Hose kits are made for stock applications, unless noted otherwise.
Hey guys, just an FYI on stainless braided brake lines...We have tried every brand manufacture out on the market over the last 12 years..The reason why we think the Russell Lines are the BEST is due to there CNC'd Steel Ends...Russell uses the OEM spec's to build there ends and the biggest difference is on the end which bolts to the caliper...Russell's is a square block like OEM...Which gives much more contact sufface for sealing and strengh...Russell also allows you to use the OEM bolt, which seals better in the caliper and the square OEM spec'd end...
Call Mike directly to order yours!!
These are the 2005-2010 C6 Stainless Braided Kit
These are the 2006-2010 C6 Z06 & Grand Sport Stainless Braided Kit
Thanks,
We accept Visa, MC, Disc, Amex, Paypal and Cashiers Checks!!!
St. Jude Donor '11-'12-'13-'14
Any idea how long the special will continue? I want to pick up a set, but we just bought the car and the wife wants/needs me to hold out on mods for a month or 2.
What's the hardest part about installing these, is it bleeding the system?
Former Vendor
Basicly yes, but thats why 9 out 10 people who buy stainless lines also purchase the SPEED-Bleeders too...
The last car I bled brakes on was a 79 Trans Am. With speed bleeders, is it basically the same procedure?
Former Vendor
Yes we always keep these instock at all times...call me to order...thanks
