DOT 3 To DOT 4 brake fluid upgrade?
It says in my owners manual that they recommend changing the brake fluid for track events. I assume the stock fluid in my GS is DOT 3??? Is there a special procedure required to change the brake fluid? Or so we need to do a manual bleed on each caliper? I want to upgrade to DOT4 fluid for track days. Why would they not put in DOT 4 from the factory???
Yes - the stock fluid in the brake system is DOT 3.
They do put DOT 4+ in the clutch system at the factory due to the heat from the engine, but DOT 3 is perfectly satisfactory in the brakes for street driving.
DOT 4 is slightly more hygroscopic. Here's an excerpt from a StopTech Technical White Paper:
Read all about brake fluid here:
http://stoptech.com/tech_info/wp_brakefluid_1a.shtml
DOT 3 comes in the brake system from the factory mainly because there's just no reason to spend one extra penny to put something else in, and DOT 4 also would require more frequent servicing of the brake system and most owners probably don't even get their DOT 3 flushed as often as they should.
You can flush some DOT 4 into the system just like you would with any other car, except that without a Tech 2 you can't flush new fluid into the ABS circuits. You can flush, go out and do a couple ABS stops to get fresh fluid into the ABS lines, then come home and flush again if you really feel the need to try to get new fluid into the ABS before going to the track.
BTW, your GS has fixed calipers, so you'll need to bleed through both the inside and the outside bleed valve on each caliper when you flush the system with DOT 4.
Bob
DOT 4 fluid will have a more stable and higher boiling point during the early portion of its life, but ironically once the fluid does actually begin to absorb water its boiling point will typically fall off more rapidly than a typical DOT 3......
....Does this make DOT 4 fluids better than DOT 3 fluids? ....The real differentiating factor should be that if you run a DOT 4 fluid you really should change the fluid more often than if you use a DOT 3, if for no other reason than the rapid fall off in boiling point with time.....
Bob
Thanks for the info. So the real question is do people generally feel that upgrade to DOT 4 is really needed on these cars for light track duty? Or does the stock braking system work fine with the factory fluid. In other words I don't want to go through all the work of swapping out the fluid to DOT4 if it is not really needed, I used to subscribe to the overkill mentality and perhaps it is really one of those "it depends how hard you drive the car" issues. Thoughts?
When you get tech inspected at the track they're mainly just looking for clean fluid and a good level in the master cylinder, and they can't tell what DOT spec is in there unless you tell them.
Many events probably don't specify what you use, but the Nat'l Corvette Museum does for their HPDE's.
Here's an excerpt from the "Getting your car ready for High Performance Driving Educations" document from the NCM about preparing your car for the VIR HPDE the end of June:
Brakes – The brake system should be in good working order with no leaks in the system. The brake lines should not have any cracks. The brake fluid should be clear & at the maximum level and have the brake system completely flushed with new brake fluid within the past 60 days. Good DOT 4 brake fluid, Motul, ATE Super Blue / Gold, Ford HD, Wilwood brake fluids, Castrol SRF or any brake fluid with a Wet ( not dry ) boiling point around or above 400 degrees. DOT 5 silicon bake fluids must NOT be used in cars with ABS systems.
We recommend that your cars brake pads be a minimum of 60% or the original thickness [NOT of ceramic composition] used in normal street braking applications. The brake pads should have plenty of life left in them, as the high speeds on the track will wear them out faster than the street. The brake lights should function properly.
Read the whole document here:We recommend that your cars brake pads be a minimum of 60% or the original thickness [NOT of ceramic composition] used in normal street braking applications. The brake pads should have plenty of life left in them, as the high speeds on the track will wear them out faster than the street. The brake lights should function properly.
http://www.corvettemuseum.com/regist...20a%20HPDE.doc
Here's the checklist for participants to prepare their cars for the HPDE:
National Corvette Museum High Performance Drivers’ Event
- PRE-EVENT SAFETY INSPECTION CHECKLIST -
TO BE COMPLETED BY YOUR MECHANIC
You must have your vehicle inspected by a certified mechanic within 30 days of attending this event. The mechanic must complete and sign the front of this sheet after the inspection. Present this completed sheet to the one of the NCM tech crew for the event day inspection.
Driver: ________________________________________ _____________________________
Make/Model: ____________________________ Yr: ____________ Color: ______________
Plate #: _________________________________ State: ______________________________
__ BATTERY: securely mounted
__ BELTS: no cracks, tight
__ FUEL LINES: no leaks, pinching
__ THROTTLE LINKAGE: not sticking, free travel, and return spring good
__ COOLING SYSTEM: clean antifreeze, no leaks
__ BRAKE FLUID: clean, full, DOT 4 within 30 days of event__ BRAKE PEDAL: firm
__ BRAKE LIGHTS: in proper working order
__ BRAKE PADS: at least 1/2 of full thickness; new preferable. Ceramic pads not recommended
__ BRAKE CALIPERS: clean and dry
__ BRAKE LINES: in good condition
__ WHEEL BEARINGS: no leaks, tight, little play
__ WHEELS: no cracks, torqued to 100 lbs
__ WHEELS: 5 regular bolts, no locking nuts or trim caps
__ TIRES: 3/32” minimum tread, DOT approved, NO R-COMPOUND FOR BEGINNER OR NOVICE!!
__ TIE RODS: no play
__ SUSPENSION: no rust at stress points, no excess play
__ SHOCKS: no leaks, firm
__ EXHAUST: integral, muffler required
__ ENGINE/TRANSMISSION: no leaks
__ STEERING: no excessive play
__ GLASS: no cracks
__ MIRRORS: inside and outside
__ WIPERS: working, with efficient blades
__ SEAT BELTS: three-point required, reciprocal rule enforced. Passenger seat must have the equivalent safety belts/harness as the driver seat.
__ ROLL BAR if present (SCCA Solo I or better meeting Broomstick Test subject to verification)
__ FIRE EXTINGUISHER: optional, should be mounted metal to metal if present, in car or trunk
Inspected by: ________________________________________ ______ Date: ________________
Address or stamp:
You can see the one document says flush with DOT 4 within 60 days of the event, and the checklist says within 30 days.- PRE-EVENT SAFETY INSPECTION CHECKLIST -
__ GLASS: no cracks
Address or stamp:
So....If you're going to flush your system before a track event, you might as well put in a good DOT 4 fluid.
When I flush fresh fluid into the system, I think it usually takes about 1-1/2 qts. I use Motul RBF 600, which is a DOT 4 and comes in 500ml containers (about a pint). I'll use 2 to 3 bottles (1 liter to 1-1/2 liters)for a good flush.
It usually takes anywhere from about 8 to 12 ounces from each rear caliper to get fresh/clean fluid coming out, and because of the shorter lines up front it takes about 4 to 6 ounces from each front caliper - but I just bleed until I'm getting nice clear/fresh fluid coming out.
You're gonna have to decide for yourself how much effort you want to put into preparing your car for track events, and what the requirements of the sponsoring organization may be.
Have fun at the track!!! Are you going to the NCM VIR event? C'ya there if you're going!!
Bob
Received 2,051 Likes
St. Jude Donor '13
Bob-
Do you have any info on how long it takes for DOT 4 to degrade below DOT 3 performance? I now have GM DOT 4 in my 2009 Coupe, and plan to flush once per year (no track use, but vigorous mountain driving).
The article also mentioned possible compatibility issues brtween DOT 3 brake systems and DOT 4 fluid, but then seems to say that's only a problem on older cars. The DOT 4 seems to be doing fine in my car, but it's been in there less than a year. Your thoughts?
Received 8,928 Likes
If you are using stock pads it is unlikely you will get the fluid hot enough to boil new GM DOT3 fluid since the pads don't operate at that high of a temp. However, I always used the Ford fluid until they dropped the dry boiling point spec from 550 to 500 degrees. It is still one of the best fluids on the market for the price. Hawk HP+ pads have good friction at 800 degrees F and a race pad like a Carbotech XP12 probably can generate 1400 degree temps if you are running race tires and can use all of the friction the pads provide.
If you are a novice or low level intermediate track driver the Ford fluid is a great choice due to the high dry boiling point and the fact you can get lots of it cheaply at the Ford dealership. I used to go and buy 8 to 10 cans at a time.
Bill
No, Jim - I really don't know.
Like the StopTech document says brake fluids....:
It also says to buy small containers of fluid, because once you open it atmospheric moisture can be absorbed, so you don't want to keep opened containers. The common forum wisdom is that after using fluid from a container, even if it's tightly sealed most people say it's no good after a couple weeks on the shelf.
Many people say that you shouldn't remove the cap from the brake or clutch reservoir or you're letting moist air contact the fluid and transfer moisture, but I think that's very ****.
Many people don't like using a Motive Power Bleeder to apply pressure to the fluid to push it through the system when bleeding. As mentioned in that StopTech article, they think it pushes moisture from the atmosphere into the fluid. I use a Motive at 10-12 psi, and I don't think it puts any appriciable amount of moisture into the fluid that it won't absorb through breathers, seals, etc.
There's another type of pressure bleeder that uses a diaphragm to apply mechanical pressure on the fluid rather than air pressure, and if I were a professional racer using Castrol SRF I'd probably do every anally obsessive little thing regarding every aspect of maintenance on my car, but as an HPDE guy that goes to the track for fun and doesn't push for every last 1/10th second every lap, I don't think I'm compromising at all by using my Motive Power Bleeder to flush the brake system a week or two before every event.
If you live in a real dry climate the fluid may not absorb as much water over time as it does where I live in damp/humid/muggy/boggy Florida!
I would think that whether you're running DOT 3 or 4, a flush every year is plenty good unless you're tracking the car. Probably every 2 years would be okay.
If you track the car, flush before every track event, unless maybe you're running Castrol SRF, which is in its own class!!! Even the racers that put in SRF will run it multiple events, maybe even a whole race season, without any problem.
Bob
....are hygroscopic in nature - i.e. they adsorb water at every opportunity. Since water boils at 212 degrees Fahrenheit (100 degrees Celsius) the adsorbed water dramatically lowers the boiling point of the brake fluid. A minute amount of water suspended in the fluid decreases the boiling point as much as 1/3. Damn!
The fluid in the system absorbs water through the breathers, through the caliper piston seals and by magic.
Bob
St. Jude Donor '13
Thanks. I note that you are using (good) DOT 3 rather than DOT 4, are you aware of any problems or just being extra cautious to follow the exact GM recommendations?
