simple brake pad question
Hi everyone,
Sorry if my question is very basic and somewhat silly, but i am a very new owner of a yellow 2007 C6. I wanted to order new front + back brake pads, and noticed that most online stores offer two types:
- Rear+ Front pads, corvette, w/o z06, w/o heavy duty brakes
- Rear + Front pads, corvette, w/o z06, w/heavy duty brakes, 6.0l
So, whats the difference between the two? will they both fit my car? because the price difference between the two is pretty high
Thanks,
alex
Thanks,
alex
Received 8,915 Likes
The brake pads for the heavy duty brakes and the standard brakes are the same. The heavy duty brakes use larger diameter rotors and the identical caliper the base car uses. Not sure why there would be a cost difference unless the pads for the heavy duty brakes have a different compound but that shouldn't make a large difference either. What brand and type of pad are you looking for?
I just checked KNS Brakes a forum vendor and the pads for the two are the same cost.
http://www.knsbrakes.com/searchResults.php?car_id=250
Bill
Bill
I just need oem replacement front and back pads thats it. But got confused when i saw these two options !!! my C6 came with slotted rotors. So which pads will i need to get now?
Rear pads, corvette, w/o z06, w/heavy duty brakes., 6.0l 06-07 $95.06
Rear pads, corvette, w/o z06, w/o heavy duty brakes. 05-11 $228.02
see the price difference?
GM didn't deliver cars with slotted rotors so you have aftermarket rotors. Check the RPO list on the glove box door and see if you have FE3 and Z51 or F55 showing in the list of of options. The Z51 and I believe the F55 cars got the heavy duty brakes which came with larger drilled rotors.
Bill
Bill
GM didn't offer slotted rotors so you have aftermarket rotors. Drilled rotors came with the heavy duty brakes and the only difference between them and the base rotors other than the drill holes was the diameter. Z51 and I believe F55 cars got the heavy duty brakes. Check your RPO sticker in the glove box for either of those two options.
I checked a couple of other forum vendors that have GM parts and it looks like their common web pricing tool may be screwed up. They have the base brake pad kits priced the same as the Z06 brake pad kits and those two kits are considerably different. The Z06 kit includes the pad pin bolts which run well over $100 from almost any supplier. If you are trying to purchase from GM Parts House or Parts Taxi I would suggest calling them directly. Either Gene or Kevin will work with you to make sure you get the correct part at a good price.
Bill
Bill
Bill
Bill
I also tried to check my VIN online but couldnt get the info i needed> i asked the previous owner and he said the car came with slotted disks. the VIN is : 1G1YY26U475104188
Hope you could help me out
i forgot to mention that i'm located in the gulf region and local GM dealers dont know anything.They charge around $300 for front and $300 for back pads. Thats crazy, I never thought buying brake pads would be so hard.
Thanks for trying to help me out here. I checked in my glove box, there is a huge list and i just got more confused lol
I used Compnine to check it.
Vehicle: CORVETTE 2 DR
Year: 2007
Build Date: 2006-08-04
Found 21,484 vehicles matching your year and model in our database.
RPO Description Matches
UD4 ALARM,VEHICLE SPEED(120 KPH) 120 KPH ALARM(UD4) 168
UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) LOW TIRE PRESS MONITORING SYS IND(UJ9) 20,865
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3) 13,022
UL2 RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2) 690
US3 ANTENNA DIVERSITY DIVERSITY ANTENNA(US3) 21,484
UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6) 13,022
U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19) 1,096
U3U RADIO AM/FM STEREO, SEEK/SCAN, DVD, CD, CLOCK ETR, NAVIGATION, VOICE REC, MP3 RADIO,DVD,CD,CLK,NAV,VOICE RECOGNITION(U3U) 7,661
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52) 21,484
U65 SPEAKER SYSTEM 7,PREMIUM 7 SPKR SYSTEM,PREMIUM(U65) 13,022
VBX LANGUAGE LABEL ARABIC ARABIC LANGUAGE LABEL(VBX) 168
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND JAPAN(VC5) 713
VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4) 690
V76 HOOK,FRONT TOW FRT TOW HOOK(V76) HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76) 787
V87 VEHICLE STATEMENT - GULF STATES ORGANIZATION 168
W12 NAVIGATION DISC DATA NAV DATA 2 NAV DISC(W12) 168
XFV TIRE FRONT P245/40ZR18-88Y BW HW4 (EMT) TIRE(XFV) 1,015
YFX TIRE REAR P285/35ZR19-90Y BW HW4 (EMT) TIRE(YFX) 1,015
Z5X MIRROR PROVISIONS ARABIC LANGUAGE(EXPORT) ARABIC LANGUAGE MIRROR PROV(Z5X) 168
1SA PACKAGE-OPTION 01 (1SA) SALES PACKAGE SALES PKG(1SA) 798
31I INTERIOR TRIM LT CASHMERE (04) (31I) 4,132
316 TRIM COMBINATION LEATHER, LT CASHMERE (6) (04) (316) 861
45U EXTERIOR COLOR,PRIMARY (45U) EXTERIOR COLOR-MEDIUM GREEN METALLIC (45U) PRIMARY COLOR EXTERIOR, VELOCITY YELLOW TINTCOAT (06) (45U) 1,672
AAB MEMORY DRIVER CONVENIENCE PACKAGE CONVENIENCE PKG(AAB) 13,022
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2) ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2) 15,636
AJ7 RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE INFL RST FRT & SI(AJ7) 15,636
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0) 21,484
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9) 15,636
AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) MAN RST SYS(AX4) 787
BAGPARTS PKG EXPORT PARTS PKG(BAG) 810
BGRPLANT CODE - BOWLING GREEN, KY, USA 21,484
BS1 INSULATION,ACOUSTICAL INSULATION PKG(BS1) 21,468
CE4 WASHER,HEADLAMP,HIGH PRESSURE HDLP WA(CE4) 810
CF7 ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7) 13,556
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2) 21,484
CW2 COUNTRY GULF STATES(BAHRAIN,OMAN,QATAR,UAE)(EXPORT) GULF STATES(CW2) 145
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0) 13,022
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LI GHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8) 13,022
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 15,634
EXP EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP) 810
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2) 2,777
F55 CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL VARIABLE TIME DAMPING CHASSIS(F55) 2,777
GM8 AXLE,REAR,2.56 RATIO 2.56R(GM8) 14,093
IL6 TRIM,INTERIOR DESIGN INTR TRIM(IL6) 2,961
J55 BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55) 11,767
KJ5 Unk.211KNRCOOLING SYSTEM AXLE AXLE COOLING SYSTEM(KNR) 787
KPS OIL COOLER,ENGINE ENG OIL COOLER(KPS) 4,625
K63 GENERATOR 110 AMP 110 AMP GEN(K63) 21,484
LS2 ENGINE,6.0L(364CID) GAS V8 6.0-H(LS2) ENGINE,6.0L(364CID) GAS V8 6.0-U(LS2) 21,484
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHAN DISING OPTION) A/TRANS PROVISIONS(MX0) 14,093
MYC TRANSMISSION AUTO 6 SPD, HMD, 6L-80 6-SPD A/TRANS(MYC) 14,093
NF9 EMISSION SYSTEM GENERAL, OBD MIL SUPPRESSION GEN OBD MIL SUPPRESSION EMIS(NF9) 168
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4) STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4) 21,484
N37 STEERING COLUMN,TILT AND TELESCOPING T&T WHL(N37) 12,412
QX1WHEEL 18 X 8.5 FRT & 19 X 10 RR, ALUMINUM, PAINTED FLANGLESS ALUM WHL(QX1) 945
R6K CONTROL - SALES ITEM NO. 11 20,540
SSG GRAPHIC SWITCH FUNCTION SYMBOL GRAPHIC SYMBOL FUNCTION SW(SSG) 1,096
T62 LIGHTING DAYTIME RUNNING ----DELETE T62) 787
Bill
