c6 a/c not operating
Mine was blowing hot out of one side and cold out of the other... I took it to the dealer and they found the Control unit was bad
They replaced mine with Part Number: 25938052 Hvac - Controls - Dash control unit Dash control unit, corvette 2005 - 2011
Dealer time IMO to many possibles
I agree, could be many things. If you know it has refrigerant in the system, sounds like it does from your description, then it is "most likely but not positively" the head unit or a mode actuator curtain.
What year is your car?
A/C problems SOME ONE PLEASE HELP ME !!!!!!!!!!!!
[]I agree, could be many things. If you know it has refrigerant in the system, sounds like it does from your description, then it is "most likely but not positively" the head unit or a mode actuator curtain.
What year is your car?[/QUOTE]
2006 , This afternoon I was out and the service charging system came across the DIC and shortly after that the a/c started to work. But, after I shut the car off and restarted the a/c was no longer working
Its worth a try...Disconnect your battery pull both possitive and negitive off, i beleive its for 30 Min and the computer should reset...
It maybe only 10 Min.... but i would wait the 30 unless someone can confirm the time.
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Are you on the original battery? When the battery is near the end of it's useful life, many weird things can happen.
Strange that you got a "service charging system" message, then the A/C came on.
