C6 Column Lock Bypass (Draft Design)
#41
I'd pay good money if someone would develop a plug and play option like Corvettes of Houston did for the C5....that was super simple to install.
#43
I have the same problem with my 2005 Z51 MN6 due to heat. Solution: www.corvetteworldparts.com they have a CLB for 89.95. No ripping the column apart and soldering wires and such. Includes instructions. Also a video on their web site. Takes about a half an hour to install. Must use the same great idea as mbomba. My thinking is they use solid state relays to outsmart the computer into thinking the motor is still there. will post if this is successful.
Ripper210
Ripper210
#45
Link to bypass
https://corvetteworldparts.com/2005-...liminator.html
I'll be trying this if replacing my original nine-year-old battery does not fix my Service Column Lock warning on the DIC... I'm keeping the battery alive by battery tender... DOH!
Cheers,
Doc Rings
Creator of the Original C6 FAQ
2005 C6 Z-51, 10500 miles "still smells new"!
Cheers,
Doc Rings
#47
Fix has been in place for a whole month now. No problems what so ever. Just wanted to add that you will have to remove other blue plug on right side of DIC. Gauge cluster can just be swung towards drivers door after you pull it out to the steering wheel. Most important thing is to TAKE YOUR TIME.
The Ripper
The Ripper
#49
Mine's been on since the introduction of the COH bypass solution and I've never had any issues after I installed it. Best $100 I spent.
Haven't been on the forum but I still have the car and no column lock issues after the module install. Used to be a garage queeen but she's been my daily driver for the past 3 years also, again no issues.
#50
Location: Eastern NC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Glad to see you are driving her; now catch me if you can...
