Z06 front gill insert in C6. I did it PICS
Z06 front gill insert in C6 fender. I did it PICS
Z06 front gill insert in C6 front fender. Lots of work but now the front match's my rear widebody which has the insert. I used the front Z06 insert and cut, heated, epoxied and painted it.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Nice work as usual!
You fixed a small problem I find with the widebooty conversion...the front fender looks unfinished compared to the rear fender as the rear brake duct has the bezel...which think makes it look more "finished".
What I'd like to see if a flared front air vent/scoop for the stock front fenders that can be epoxied on and stick out the extra 2" like on the Z06. You can run a 19x10 up front so the wider fenders arent needed for bigger rubber. I just think the bigger side scoop would finish the look without adding 4-5k for the front fenders and bumper.
If someone makes them, I'm first in line to pay full price.
If I can find wrecked front Z06 fenders with the side scoops intact, I'd cut them off and put them on my car and do a long spin thread called Z06ScoopMonster. Any tuners have wrecked Z06 fenders?
I had a great buying experience with Marc at Vettenuts.com - he's a forum vendor who parts Vettes. He'd be the first one I'd call for Vette junkyard parts. Don't tell him I said so but he's 1/2 the cost of our local Ft. Lauderdale Vette junkyard.
how
I'm planning on starting on the pass side today and I'll put up pics as I go for everyone to see.
one day at time
I'll be doing a how to one day at time. I do not know how far I'll get each day but I'll post pics as I go.
Cut at white lines using saw and dremil. Putty will be used latter to fill in.
next
Next thing to do.
MARK AREA TO CUT OUT AT TOP OF GRILL. WHITE LINE BOTH SIDES
I CUT DOWN THE CENTER TO MAKE CUTTING BOTH SIDES EASIER
TOPS CUT OFF
THEN I GROUND THE POST DOWN SHORTER . THATS ALL TILL NEXT TIME.
TOPS CUT OFF
MORE of how to
Push together trim down the 2 post. Then heat lower part with heat gun and install in hole after taping up fender to keep fender from getting scratched up.
Push to form it to the fender shape. This will take a few times heating.
Heat and bend over top.
more net time.
more net time.
bent over
The green tape covers the top two sides were it comes together. I used SEM #68422 two part bumper repair adhesive to fill in on parts of the gill and to bond the top together.
More next time
This is also the top corner after it's trimmed heated and bent over.
More next time
I just realized my Grand Sport Fenders are naked too...hmm. Wonder if I can get these to work? :toe tap:
They sure look nice.
shorter
THANKS RAYZZZ MY CORVETTE LIKES CORVETTE MONEY
