I'm trying to understand the fuel system
Old 09-04-2011, 04:45 PM
KKJ
KKJ's Avatar
Default I'm trying to understand the fuel system
I don't fully understand how the fuel system works on my '11 GS. It has 2 fuel tanks on it. Im guessing that the left tank fills up first, then when it gets full, it runs over into the fuel cross tube then fills the right side. We would have to have 2 fuel pumps then, right? Which side empties first, or do they both pump together?
I know running low on fuel on a standard car with one tank is bad for your fuel pump, because the fuel is what keeps the fuel pump cool. If one side empties before the other, then is one pump running with no fuel in the tank to keep it cool?
I'm also trying to think ahead for winter. I want to put a fuel stabilizer in it. Here in SD the car may have to sit for about 5 months. How would I treat both tanks equally? Thanks everyone!
Old 09-04-2011, 05:00 PM
CGZO6
CGZO6's Avatar
Everything you want to know and more:
http://forums.corvetteforum.com/c6-t...fuel-pump.html
just run the car for awhile and it will circulate the fuel stabilizer throughout both tanks
Old 09-04-2011, 05:01 PM
Motorhead-47
Support Corvetteforum!
Motorhead-47's Avatar
Although this link tells you it's for a 2003-2004 Corvette, this is exactly how your C6 fuel system works....
http://www.corvetteactioncenter.com/...el+Tank+System
And the link referenced above is a very good source of info with a ton of photos!
Old 09-04-2011, 05:36 PM
KKJ
KKJ's Avatar
Thank you! That was very informative and helpful. It was everything I wanted to know and more!
To I'm trying to understand the fuel system
Quick Reply: I'm trying to understand the fuel system
