Old 02-20-2015, 01:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
P0135, time to replace that o2 sensor?
Old 09-21-2011, 08:57 PM
Tikiman12
Tikiman12's Avatar
Default P0135, time to replace that o2 sensor?
Hello,
I'm getting a P0135 code which is for the driver side front o2 sensor. Since the code is for no heat reading I thought maybe my o2 extension wires had gone bad or burnt so I replaced it with a brand new one, code came back again.
Does that mean the o2 sensor has gone bad and I need to replace it?
I have American racing headers, my rear o2 have been removed but I have not deleted those codes yet. I'm not getting any codes for the front passenger sensor and that's what is making me think I need to replace my driver side one.
Old 09-22-2011, 09:10 AM
Tikiman12
Tikiman12's Avatar
bump
Old 09-22-2011, 11:45 AM
Motorhead-47
Support Corvetteforum!
Motorhead-47's Avatar
P0135 is Bank 1 Sensor 1...forward driver's side o2. If you are getting the code it sounds like you have a bad sensor. This is a common part and should be available at just about any auto parts store.
Old 09-22-2011, 12:16 PM
Tikiman12
Tikiman12's Avatar
correct.
I just wanted to know if I was correct my diagnoses and if there is something else to check before I put a new o2 sensor on there.
Also I checked the fuse and it is fine
Old 09-22-2011, 12:40 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
If the wires are in good shape the code could be caused by either the ECM or the O2 sensor. Since you don't have the ability to check out the O2 sensor or the ECM the fault is more than likely in the sensor so it is probably cheaper to replace the O2 sensor and hope that is the cause of the code.
Bill
Old 09-22-2011, 12:43 PM
Tikiman12
Tikiman12's Avatar
thats what i'm thinking too.
Thank you Bill
Old 09-22-2011, 03:08 PM
Tikiman12
Tikiman12's Avatar
Terminal Function
A HO2S Low Signal
B HO2S High Signal
C Not used
D Ignition Voltage
E HO2S Heater Low Control
According to this diagram, I can check the E and D with an OHMS meter to see if my "heater" is working?
Or would I Touch E and a ground?
Old 09-22-2011, 07:29 PM
Tikiman12
Tikiman12's Avatar
Ok I touched E and D on the u2 sensor, not plugged into the car. And it pegged my ohm meter all the way to the right, this makes me think the heating element is working.
What could be the cause of the p0135? Could the sensor be clogged and I need to remove it to clean it?
Old 09-23-2011, 07:53 AM
Motorhead-47
You're troubleshooting is flawed. A dead short across those two pins does not tell you the o2 sensor is working.
The o2 sensor is probably the most commonly replaced failed part in modern cars. Your car is a 2005?....a 6-7 year old oxygen sensor. I don't know what you value your personal time to be worth but if it were me, I'd swap that bad o2 sensor and move on. If you haven't convinced yourself yet that it has gone bad, flip flop the driver's side o2 with the passenger side o2 and watch where your problem goes...you'll be looking for code P0136.
Old 09-23-2011, 09:08 AM
Tikiman12
Tikiman12's Avatar
true, and I'd agree if my o2 was old. but my sensors are new as of 2 months ago lol.
Swapping sides is a good idea for a test
Old 09-23-2011, 09:40 AM
Bill Dearborn
Swapping is a great idea.
Bill
To P0135, time to replace that o2 sensor?
Quick Reply: P0135, time to replace that o2 sensor?
