Need closeups of fuel pump assembly connectors anyone?
Need Closeups of the connectors to the OEM fuel pump and level sensor (outside of tank) so I can track down the right plugs before I pull it out (So I don't have to cut wires)
If anyone has an OEM assembly laying around or has their tanks out I would appreciate it, will share connector part numbers once I find them.
BJK
If they have male pins and you have digital calipers it would be great to get the pin width, but I am also assuming they are of the 1.5mm wide variety, although the fuel pump one might be bigger due to the load.
I have the tank sitting on the floor in the garage but it has a RSI hanger installed. Do you want to see the connector on top of the C6 pump? As in the connector that the factory harness plugs into?
BJK
BJK
I just found a better picture HEREbut I still need closer up.
So a picture of the 4 pin connector, close up of the pins, and the harness side as well if you can. If you can get a pin width that would tell me what series connector as well.
If you really want to go above and beyond, if you could tell me if on the harness side, on the back, if the grommets that seal the wires are separate on each wire or all one grommet that would tell me if it is a pull through connector or not (which would mean 0 hope of getting the female connector)
Just wildy guessing/hoping these two are right, specifically if the first one is the harness side plug to the fuel pump, then the second one will definitely work since it is a defined mate (even if it's not identical to the pump)
Exterior Dimensions 30.5L X 19.5W X 31.6H
http://www.mouser.com/ProductDetail/...EA7S9JkSSAw%3d
Exterior Dimensions 39.8L X 30.2W X 48.4H
http://www.mouser.com/ProductDetail/...2R5DXJGQ%3d%3d
I found the harness side connector part number it's ac delco tech connect PT1537, I don't think a matching socket exists though, which is the part needed if you want to take off from the factory wires without cutting .
I better clarify the photos. The white connector is on top of the of the fuel pump.
The blue and gray connector plugs into the white connector.
the black and blue connector plugs into the car harness.
The pins in the white connector look to be about 2.5mm.
BJK
BJK
connector on top of fuel pump -> blue gray connector (plugs in) -> wire extension -> black and blue connector plugging into a larger harness?
If so I think I can definitely find the other end of the last one since it looks to be a delphi connector.
When you say the blue connector plugs into the car harness, do you mean it goes
BJK
Here is the black connector itself I believeHERE Could also be this one actually (first one is a 1.5mm blade withdth version, this one is 2.8mm blade width) HERE
This will make a much cleaner install of fuel pumps IMO.
I'm pretty sure they are 280 series connectors meaning they have a 2.8mm blade width, if so they are FEMALE MALE or MALE 2 (seem to be the same)
If they are 150 series and have 1.5mm blade width they are FEMALE MALE
I'm 90% sure they are 280 series because of the current and because delphi says THISis the 150 series which is purple inside, and the 280 series definately has that blue sealer.
So if you are looking for a super clean install of a fuel pump order THIS with associated pins and grommets. Can be ordered from HERE for pin and seal part numbers go to "related parts" HERE and plug them back into mouser. Oddly it looks like no ones sells the large blue connector seal, so hopefully it comes with the connector itself. (or you can just steal it from the original connector)
