New 15" Drag Pack
New 15" Drag Pack
I have been working on this project with LG with some other stuff over the past few of months while other forum members started doing 15" rears. I always wanted a full 15" Weld RTS drag setup to be different and to get some more sidewall for the drag strip. LG delivered very nicely. Rears tuck in a little so I can run a little wider tire later on without having to worry about rubbing the outer fender. Here are some quick pics. Enjoy.
What changes or modifications are necessary to accomodate the 15 inch wheels? My present set up is a 08 Z51 wide body rear. Presently running 17x11 inch C4 ZR1 rims with Hoosier 315/35 17's. Thanks .....Mike
Hm...
It looks mean as hell, but I think it's WWAAAYYYY overkill and too much sacrifice in braking.
A drag radial on a 17" wheel will take these cars further in the single digit range than 99.99% of people will go.
If you wanted it just for looks then job well done, because it looks great.
Very cool!
I saw you made the LG Newsletter too. Do you get that? email me at joegut at gmail and I'll forward to you if you don't.
Hopefully LG can respond and give more details on the setup specs.
I've tried drag radials. No traction. That is why I went to 17" bias ply. I went with 15" for looks and for more sidewall.
J
Received 2,054 Likes
Looks good! You better hurry and get to the track before Dallas Raceway turns into a truck stop
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Depending on the wheel, most are going to require some minor clearance of the caliper to fit the inside of the rear wheel.
Andrew did a 15" front as well, which for him required the use of a small front brake as well. Given the 4" wide front tire, a big front brake would be pointless.
Again, it looks good....so there's that going for it
It is pretty radical and costly as well but I suppose he just wants to be sure that he hooks every single time (of course there is no way to be truly sure).
