C6 Automatic Transmission Filter Change
Old 10-24-2011, 10:11 PM
96BAM
96BAM's Avatar
Default C6 Automatic Transmission Filter Change
Asked in General Discussion. No luck there. Will try here.
Any one chaged out the A6 filter yet???? If you have how did you get the back 4 bolts out.
Old 10-25-2011, 12:03 AM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
I have all of my fluids changed out every 20,000 to 30,000 miles as well as the A6 filter. PM sent.
Old 10-25-2011, 12:43 AM
1Corvette
1Corvette's Avatar
Check this article. It should answer your questions.
http://forums.corvetteforum.com/1570779410-post5.html
Good luck
Old 10-25-2011, 09:18 AM
96BAM
96BAM's Avatar
Thanks but that is just for fluid level check. I need to pull the pan off in order to change the filter. All the shop manual say is to remove 18 bolts. Can't get to the back 4 under the cradle.
Old 10-25-2011, 10:03 AM
Gering
Tolero Apto Victum
Gering's Avatar
In order to get to some of the bolts, I believe we removed the (4) nuts "see green" then we placed a brace "see blue" and raised the trans a little.
Old 10-25-2011, 02:02 PM
96BAM
96BAM's Avatar
That is correct on removing the 4 nuts. 2 on each side. Then raise the trans. From start to finsh took about 2 hours. Just finished.
Old 10-25-2011, 05:00 PM
Gering
Tolero Apto Victum
Gering's Avatar
Good to hear!
Old 10-26-2011, 07:42 AM
pmj341
pmj341's Avatar
St. Jude Donor '08-'09-'10
The pics showed are the rear end drain and fill, Not the trans!!
Old 10-26-2011, 12:02 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
He noted that the area circled in green was what was needed to raise the trans (man or auto). It was a multi-function photo.
Old 10-26-2011, 08:53 PM
Gering
Tolero Apto Victum
Gering's Avatar
The pic is not perfect, but it will work for a quick reference. We have replaced my 07 A6 filter many times before "every 20,000 to 30,000 miles" which has well over 120,000 miles on it. For those that wish to do the drain, drop pan, clean pan, replace filter, install pan, & refill; I would recommend you drain and refill the diff at the same time.
Gering
Tolero Apto Victum
Gering's Avatar
Old 10-26-2011, 08:56 PM
Gering
Tolero Apto Victum
Gering's Avatar
Also here is another thread about the same topic.
http://forums.corvetteforum.com/c6-c...er-change.html
"Linked for those that are doing a search about the topic"
Old 10-28-2011, 05:27 PM
Gering
Tolero Apto Victum
Gering's Avatar
I just wanted to post this pic of my C6 A6 trans that I took this afternoon.
Old 10-29-2011, 01:19 PM
pmj341
pmj341's Avatar
Now that is a proper picture of the A6 trans with pan removed
Old 10-30-2011, 11:16 AM
Gering
Tolero Apto Victum
Gering's Avatar
Old 03-29-2013, 05:35 PM
southpaw5000
southpaw5000's Avatar
I could snap a pic of my transmission and it would look identical to this. Man what a pain in the butt this project is. Exhaust torn apart, rear suspension bolts removed yadda yadda. Thankfully I have a hoist. I cannot imagine doing this on jack stands. I should have just took it to the stealership but I am too stupid and stubborn.
To C6 Automatic Transmission Filter Change
Quick Reply: C6 Automatic Transmission Filter Change
