CEL and "Service Traction System"
I posted this in C6Z06 but was hoping someone else would have some real experience or have a good idea whats going on:
Since my new motor was installed I have been getting CEL with the Traction Light and DIC "Service Traction System"
The Throttle Positon Sensor was replaced as the OBII indicated that was the reason the car was running rough and tripping CEL and DIC messages.
The car now runs smoothly but the CEL/DIC keeps coming back. It seems like it takes about 30 miles of driving to trigger the event. The car was road tested a few times by dealer and all seemed fine, but they only drive it about 10 miles.
I am able to place the car in Comp Mode while the CEL and DIC are displayed.
So does anyone know what the problem is?
Is the car safe to drive at the track in this condition??
DH
DH
Check your brake fluid level.
DH
DH
I have always been happy with my dealership (Paradise Cheverolet in Ventura California). I'm sure they will get to the bottom of this. But since they just put a new GM engine my car I know there are some might be some little gremlin causing this such as a bad wheel sensor or shorting wire. My SR is off for a few days so I am going to call the SM and see what he thinks and make sure its safe to drive my car. It sure feels good to have it back and with a brand new motor as well.
It is obvious to me by your presence and GM's warranty policy that you guys really care about us customers. I'm sure GM is winning many life time customers ( I was already one before, this is my 6th Vette)
GM
DH
When I installed a Vette Air scoop and an Attack Blue filter element on my stock Z06, I would get the "service traction Control" and "service active handling' along with the CEL with terrible surging. First I removed the Attack Blue filter and put the OE Donaldson PowerCore filter element back in. That got rid of most of the surging and got rid of the CEL and the two warnings(most of the time). I then made a diffuser plate to keep the air being discharged from the Vette-Air from hitting the face of the stock filter head on. Turbulence across the MAF was causing my problems. GM has a TSB that addresses this problem. Air leaks around the base of the radiator shroud and from holes in the bumper beam can cause this turbulence that will set the codes.
DH
It happened to me. All kinds of warnings about service active handling, trac control, and then finally some message about brake fluid(?), I can't remember. It was low, but not real low. Topped it off and it was cured.
Also the waring is always the same ........... 'SERVICE TRACTION SYSTEM". Nothing else and nothing about AH/TC. But the TC dash light does come on and off
I will be checking tommorrow
DH
Codes found:
P0300: Misfire
P0430: Cat Passenger side
Oiled cat from engine failure makes sense.
Misfire worries me cause I don't know if this was when engine blew or after. Maybe in happened when car stalled or during limp mode ??
There were no codes found in the BCM
Putting some g-force load seems to trigger the DIC message "Service Traction System" and lights up the Traction Control lamp.
DH
P0300: Misfire
DH
I am having having a similar problem. Under full throttle only and it has to be above 75 I get the Service Traction System light coming on and the SEL flashes a misfire. I back out of the throttle and afte a few seconds it all goes away and everything is good.
I had to replace my starter though, so checking that ground wire sounds like a very good place for me to start.
DH
Received 8,926 Likes
Born 53 (09-21-2019)
Codes found:
P0300: Misfire
DH
P0300: Misfire
DH
My right side cat has the same code after the engine replacement. Been driving with it that way since 10/11/11 and haven't seen a Service Traction Message. Have been waiting for parts for over a week.
Bill
As I said in the previous post a misfire code will disable Traction Control. Misfire could be a spark plug wire issue.
Bill
Bill
It was flashing for a couple of days but then the CEL has been on steady.
Funny you should say plug wire. I was going to have them replace them and then forgot .......
DH
