LS2 lower injector o'rings
Does anyone know the part number for the lower injector o'rings for a stock LS2 injector. I was replacing the stock fuel rail and I noticed a few o'rings had some small nicks. The local parts houses show o'rings for this application, but they're the wrong size. They look like LS1 o'rings. The stock ones are color coded "red". I would hate to call the stealership but if I must - I guess I have to. TIA.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Sadly, they are a different size than the top O-rings. The parts book misses that fact entirely. I swapped out the injectors and went to the dealer for rings and we were given the wrong ring. I had to re-use the old rings because they had no other listing.
Really sad....
Really sad....
I might still have my stock o-rings, I replaced them with the ones that came with my Fast intake when I performed the swap.
If I can locate them, you can have as many as you need.
If you find them, you can send me an email to lpg1045@rgv.rr.com.
I only need 2.
