Need help identifying a wire on the starter. (service charging system)
My car started to display the "service charging system" warning today, after my first run at the track. I replaced the alternator, checked the horn, and the battery will take a charge using jumper cables. The only think I can think of, is a disconnect between the alternator and battery. My volt gauge in the dash never goes above 10 or 11, and does not increase with RPM. Instead, it slowly drops as I drive the car until the batter is dead again.
While feeling around the starter, I found this wire just hanging there, so I pulled it to the front for a closer look.
I found the same wire on another website, connected to the starter.
My battery has been relocated to the back, and I am not sure whether or not this wire was removed during the relocation, or if it broke off today.
Thanks!
