pro charge vs turbo charge kits
Old 12-22-2011, 05:18 AM
snowwhitec6
snowwhitec6's Avatar
Default pro charge vs turbo charge kits
i have a c6 ls2.
i want to know whats better for my motor turbo or pro charger?
also what kind of turbo kits and pro chargers kits are the best?
my goals are to have the least problems with either kits and to have around 450-500hp to the wheels.
Old 12-22-2011, 09:44 AM
0HorsePowerAddicts
Former Vendor
HorsePowerAddicts's Avatar
Pick up an A&A Corvette supercharger kit. You will make over 500 RWHP though.
http://www.aacorvette.com/supercharg...fnlt7mdrlc2pg0
Old 12-22-2011, 09:45 AM
FloydSummerOf68
FloydSummerOf68's Avatar
I agree....A&A kit. Price is unbeatable and quality is great.
My LS2 A6 put down 624rwhp SAE corrected with an A&A kit, alkycontrol meth kit, longtubes and catless x-pipe on 10lbs of boost.
Old 12-22-2011, 10:37 AM
seung012
seung012's Avatar
Anything turbo can become headaches. If turbo/s go out, they are very hard to reach versus superchargers, which are in front. Turbos create more power with hell of a curve on the dyno but supercharger IMO is best for reliability and maintenance.
I recommend ECS... especially if you are in east coast.
Old 12-22-2011, 01:16 PM
snowwhitec6
does the a&a sc kit have the least problems out of the other sc ?
Old 12-22-2011, 01:18 PM
snowwhitec6
have u had any problems with your a&a kit?
Old 12-22-2011, 01:34 PM
FloydSummerOf68
It literally just finished geting tuned last night, lol.
But I haven't heard of anyone having any typical problems with it.
Old 12-22-2011, 01:47 PM
snowwhitec6
lol thanks for the info
Old 12-22-2011, 05:05 PM
DSOMC6
DSOMC6's Avatar
You obviously don’t own nor drive a twin turbo C6?
The only reason NOT to install a twin turbo system over a supercharged set-up is budget IMHO. It will cost you quite a bit more for a TT set-up. Todays TT kits are highly reliable…especially with oil and water cooled turbo’s. They are virtually maintenance free. Turbo’s seldom IF EVER “go out”. If you have a turbo failure you either have very cheap (Chinese made) turbos or they are older versions that do not have the cooling capability’s as todays turbos have. The days of turbo timers (for cooling after shutdown) are looooong gone.
The only required maintenance is your regular car maintenance ie: engine oil, coolant flush and air filter cleaning. How is that any different than a non-turbo bone stock LS engine?
Yes a turbo set-up will make more power, torque and are MORE reliable. I’ll even go as far to say that they are easier on an engine because of the design (how they make power) and are more efficient at making said power. You have the low-end torque of a roots blower and the peak hp of a PD blower. It's a win win set-up.
There are no pulley swaps/retunes to make more power as required with a SC. You simply just turn a **** on the boost controller to increase/decrease boost. An electronic boost controller can be utilized to limit boost in lower gears, at lower rpms to increase traction and allow full boost upon appropriate RPM’s. There are no slipping or broken belt issues either.
The biggest and only downside is the initial installation/labor cost (if you are not doing the installation).. If you don’t have the funds in the budget, then, as others have mentioned, A&A, ECS etc makes awesome kits for less money. If the OP is looking to save money and only wanting to make 450-500whp then it would be less costly to go SC.
Old 12-22-2011, 06:34 PM
Venom_C6
Venom_C6's Avatar
Agree. I wish I had more money for twin turbo.
Old 12-22-2011, 09:42 PM
Devilish34
Devilish34's Avatar
And you are here posting on the interweb and not out driving !?!?!
Oh the madness
Old 12-23-2011, 01:24 AM
FloydSummerOf68
Oh the madness
Not much point in driving right now...streets are too cold. Even with 345s it spins at 60mph.
Old 12-23-2011, 03:24 AM
07MontRedcp
Support Corvetteforum!
07MontRedcp's Avatar
Seeings how we both have the same APS TT kit I can agree 100%.
BJK
Old 12-23-2011, 03:53 AM
winters97gt
winters97gt's Avatar
You could just borrow my 28 inch tall MT's. I can assure you that you will hook!
Either an ECS or A&A kit. I've had both, and like each one of them. You can run a 4.0 pulley and a real conservative tune, and it will probably make low 500's on a stock ls2. Motor will live forever with a good tune at that power level.
Old 12-23-2011, 08:37 AM
turboffr
turboffr's Avatar
St. Jude Donor '10
i have a c6 ls2.
ECS....you'll be very happy
Old 12-23-2011, 02:30 PM
3 Z06ZR1
3 Z06ZR1's Avatar
[QUOTE=winters97gt;1579544841]You could just borrow my 28 inch tall MT's. I can assure you that you will hook!
QUOTE]
Oh come on! the MT's are going to hook in freezing weather!
Old 12-23-2011, 04:41 PM
winters97gt
[QUOTE=Rock'n Blue 08;1579548280]
QUOTE]
It doesn't freeze where floyd and I live. About 50's on average.
Old 12-23-2011, 07:26 PM
haljensen
haljensen's Avatar
Tough question to answer since a Procharger is a company that makes belt driven superchargers and a turbo charger is exhaust gas driven form of forced induction.
Maybe go to the Forced Induction forum and ask "What is the difference between Turbo charging and a belt driven Supercharger?".
Google?
Old 12-23-2011, 08:27 PM
FloydSummerOf68
ha ha...after getting this thing installed I can't even IMAGINE all of the people who do blowers and keep the stock 285 runflats. The Khumo XS are supposedly some of the stickiest street tires (not including R compound "legal" tires) you can get for dry conditions (and the 345s are not only wider, but also taller than stock) and they're useless under 60 with our current temps.
It boggles my mind to think about it because I see it so often.
To pro charge vs turbo charge kits
Quick Reply: pro charge vs turbo charge kits
