Mass Air Flow Sensor damaged by SLP Batwing?
I installed SLP Batwing cold air induction, and two months later the check engine light is on, took to dealer and was told the oil in the filter messed up the sensor and it has to be replaced.
FIX: remove the cold air induction and put stock ( paper filter) back on then replace sensor.
Has anyone else ran into this issue? If so what did you do?
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
It just needed to be cleaned, sorry to say but you were taken.
(unless it just coincidentally failed of course which is rare)
Track Junky
If you have a steady hand, you can use rubbing alcohol and a Q-tip to clean. be EXTREMELY careful if you do this as you could damage the resistors or wires. If you aren't entirely comfortable, use the spray and reset the engine codes.
This isn't really a big deal, so don't worry too much.
Sean
Sean
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just use MAF cleaner and spray the MAF clean. Its that simple.
BC
BC
Thanks guys for response. No I did not purchase anything nor did I take off my current SLP breather...dealer did say is was not "pending doom" but it needed to be addressed. Will get the cleaner and get the code reset.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do your self a favor and purchase your own code scanner. AMAZON has some good deals. I purcased the ACTRON Scanner
BC
BC
Got it, applying tomorrow on day off.
