Royal Purple or Red Line
It's time to change the tranny & differential fluid. I have heard great things about both purple and red line products. Does anyone have any insight on things to be aware of? Red line tranny fluid doesn't really specify if it is for use in the vette tranny, royal purple does. Red line seems to have the better choice for diff fluids, Any input would be appreciated.
Diff 75W90 rd5-7904 contains LS additive
Premium Supporting Vendor
A few years old now, but a good read:
AMSOIL Gear Lube “White Paper” (2 MB pdf file)
Of your two choices, I'd go with the Red Line.
The AMSOIL options for your C6:
Tranny:
AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
(Same fluid I use in my 02 Z06 at the track)
Diff:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
The Severe Gear 75w90 comes with friction modifier and I run that fluid in my 02 Z06 at the track without extra additive and have no diff chatter, but the C6 diff behaves differently and for the C6 most use some of the Slip Lock additive to ensure the diff doesn't chatter.
Tranny:
Diff:
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Redline in the trans made more of an improvement than the MGW shifter.
Never had diff clutch problem since I started using Redline.
Plus, Tim the owner of Redline drives a Corvette!
I just got my C6 its an 07 with 12,000 miles on it and was thinking of changing the trans fluid and rear end. Where do you guys purchase the Redline stuff?
Never had a problem with the factory fill in the differential on my 09 Z06, so it's still in the car at 4 years and 16,000 miles. When new, the car had the first to second gear nibbles, so I drained the factory transmission fill and replaced with RP. It made the nibbles worse. I then drained the RP and filled with Mobil1 ATF III. The nibbles returned back to about the same as the factory fill, maybe a little better. I wasted a bunch of money.
Never had a problem with the factory fill in the differential on my 09 Z06, so it's still in the car at 4 years and 16,000 miles. When new, the car had the first to second gear nibbles, so I drained the factory transmission fill and replaced with RP. It made the nibbles worse. I then drained the RP and filled with Mobil1 AFT III. The nibbles returned back to about the same as the factory fill, maybe a little better. I wasted a bunch of money.
i try to avoid royal purple at all cost. i do have a c5 not a c6 however. might be a good product but in my experience it beaks down WAY too quickly! i always have heard its the best, but far from it. i'd rather put the factory mob1 stuff in before royal purple. i have heard great things about redline and or amsoil. my diff is apart right now so when it gets buttoned up, amsoil is gonna be the choice of fill for all my fluids
You will get a hundred different answers and no one is better than the other. Just preference. One trans builder I talked to who routinely builds Tremec transmissions said that he just uses factory GM fluid. I have never heard of a failure or a gain in HP from one trans fluid to another lol. With that said I ran Royal Purple in both my tranny and diff and had no problems. I couldn't tell a difference with the diff but the tranny seemed to shift a bit smoother.
I too didn't notice anything negative, but drop your fluid and check to see how black it is. Breaks down too fast
