Center Console and Radio Bezel Removal
Write up
Thanks for that great write up. I am installing the new Mgw shifter this friday. This write up is going to make this shifter install a piece of cake. Bravo Zulu.
Tech info
Just installed my MGW shifter with the help of this write up. The bezel was off in under 15 min. The shifter was in in no time. Thanks for all of your hard work CDkcorvette7. Everything went right on this project thanks to you. All the best.
wideglideleon (09-22-2020)
Corvette Cowboy
cdkcorvette7 Thank you for the write-up I am C5 owner but my friend Bought a new shift ball and needed me to cut down his stock C6Z06 Shifter down and put a 9/16-18 thread on it so he can use his new Shift ball so to you great write up 15 min. to get it out.
Pops
Pops
Video
For those of us who don't visualize the written word very well, MGW has a pretty good Youtube video showing the console top removal for a shifter install. It's pretty well the same as the pictures above. Perhaps a little easier for some of us to understand exactly what is going on. http://www.mgwltd.com/corvette_short...allation.shtml
Between these pictures and the video, I think pretty well anyone, including me, could do the console removal with confidence. Thanks for your pictures.
#33
SUBVETTE
Concur on great write up! I would also endorse the contributor above that said you can simply swing the bezel over into the passenger footwell without fighting the connector for the cigarrette lighter/accessory plug. No need to remove that connector unless you want to totally remove the bezel from the car.
#36
Which iPod gateway did you install. Any pics after the install?
#37
I used the ISGM575 kit from PAC Audio. It's their PXAMG interface with all the harnesses needed.
Sorry, no pics of the install process but it's really straightforward. Just follow the steps in the write-up above then remove the radio and A/C head units, set the dip switches on the gateway per the instructions in the manual and plug it in, run enough wire out to get your iPod where you want it then put everything back together.
