Rear Hatch Struts
Old 03-29-2012, 12:38 PM
jones714
Cruising
jones714's Avatar
Default Rear Hatch Struts
Trying to install rear hatch struts in my c6 coupe.. No problem getting old ones off and new ones on. Problem now is they don't compress and trunk won;t close. Am I missing something. Thanks
Old 03-29-2012, 01:18 PM
JCtx
JCtx's Avatar
I'm about to reinstall mine on my 200-mile old car, but I can tell you they're WAY harder to start compressing, than once compressed. I know for a fact they don't fully extend when hatch is fully open, maybe for that reason. Mine 'popped' out with a bang, extending about 1/2" from the fully open position. Forcing the hatch open will allow me to reinstall them, but will probably face the same issue as you. We'll have to shove the hatch closed the first time, I'm afraid. Rather than steady pressure, a quick shove might be the best way to deal with that. It should take me about an hour to reinstall the rear speaker panels, at which time will be ready for the strut reinstall. Will comment when it's done.
But let me ask you the obvious question first: Are you positive they're the right struts? And are they identical in size, lenght, diameter of the strut, etc? I'd make sure you have the right parts first. Also make sure the thin portion of the strut is installed below (the part that should have the rubber cover). Good luck.
EDIT: Finished the job. Hatch was reluctant to go down at first, creaking in protest, but after that, it went up and down just like before. If you have the correct part numbers, just push it down man. Good luck.
Old 03-30-2012, 08:26 AM
jones714
Cruising
jones714's Avatar
Thanks a ton. Will try.
To Rear Hatch Struts
Quick Reply: Rear Hatch Struts
