Torque specs of oil pan z51
Old 04-16-2012, 01:01 AM
stevette17
stevette17's Avatar
Default Torque specs of oil pan z51
Can someone tell me the torque specs are and if the a sequence needed to tighten them?
Old 04-16-2012, 04:31 AM
CO Lightfoot
CO Lightfoot's Avatar
Torque specs: http://forums.corvetteforum.com/1580254236-post6.html
I don't know about a tightening sequence. Maybe someone will chime in.
Old 04-16-2012, 12:43 PM
stevette17
stevette17's Avatar
i see all of these how will i know which is which
Oil Pan Closeout Cvr Bolt - Left Side
Oil Pan Closeout Cvr Bolt - Right Side
Oil Pan Cvr Bolts
Oil Pan M6 Bolts - pan-rear seal
Oil Pan M8 Bolts - pan-block & pan-cover
Old 04-16-2012, 01:29 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Go to your friendly dealer and ask for a copy of the page from the service manual. If you work on your car often, consider buying the manual.
Old 04-16-2012, 01:52 PM
JRHAWK9
JRHAWK9's Avatar
Oil Pan Cvr Bolts
There will be two M6 bolts at the rear (long ones) and the rest are M8.
Old 04-16-2012, 01:58 PM
cdkcorvette7
cdkcorvette7's Avatar
This is a good thing to have on the wall of your garage... http://www.eliteengineeringusa.com/C6_Torque_Specs.pdf
Old 04-16-2012, 07:30 PM
CO Lightfoot
...right next to a hi-rez photo of your avatar.
To Torque specs of oil pan z51
Quick Reply: Torque specs of oil pan z51
