6L80 A6 1/4 Mile record
Received 2,061 Likes
Stock? Bolton? Internal? Power adders? Big displacement?
The answers are all there on page 1 of the performance list in the stickies in this forum.
John
I do not care about how the car is built just what the fastest is, mid 9's should not be a problem at all, and with traction low low 9's maybe even lower but we will see. It looks like the performance list on the forum is just CF I was looking for the overall record which may not be on the forums.
John
John
I'd start by searching out the shops who build the cars and/or the transmissions. They'll be happy to tell you about the quickest one they've built.
its not that hard since there are only a few company's building the 6l80s and finding out what I wanted to know, the record will be what my car runs.
lets see if you can run 11s firstif you beat what ever the record is its really no big deal, its all in how you do it, a turbo no big deal, supercharger no big deal, stroker and nitrous no big deal s stock block heads cam nitrous no big deal, heads and cam now that's nice, cam only nicer bolt/ons only fantastic
John
Car just competed in the Texas Invitational did very well. My estimates are from a vbox and other cars and there 1/4 mile times. If I cant lazy roll into 9's with a 850hp stalled auto and we have not even installed the NOS yet so I am fairly confident where the car will run.
John
John
I do hear that once in a while though...someone questions how a list on this board could possibly be all encompassing or all inclusive as not everyone who races is also on the internet, or at least they might not all post their results on it.
But most are and most do.
And those that aren't on these boards DO know someone who is, or someone they don't know but was at the track that day and saw the passes, or a friend/photographer of someone who knows or saw the passes made and that ET/MPH somehow ALWAYS tends to find it's way back to the Corvette Forum or LS1 Tech. Is it possible that one squeaked by unnoticed? Of course. But with all of the smart phones, WiFi and digicams out there, even the most guarded/protected info travels VERY fast nowadays.
I was at a track rental once and saw a forum member run a new best at roughly 4pm...by the time I got home at 6:30pm there were already two new threads started on it with over 25+ replies/posts between them!
So in short, yes, if it's on the Forum's C5 or C6 lists or mentioned somewhere in these internet pages, it very likely is the 'best so far' for that particular combo (or transmission).
Yep been holding the power, we have gone thru alot of R&D to get to where we are and I have to give props to Dallas Performance and Rossler to getting the car where it is. I do have to put the disclaimer out that I did Loose to Flash by a inch at TI so I am the second fastest 6L80.
John
John
If it was that easy, many others would be doing it.
And that is KEY right there. I don't care if a car has 1200rwhp, if the trans doesn't hold (and 6L80s are notorious for not liking anything more than 500-600rwhp, especially with a power adder) or doesn't shift when it's commanded to do so, the car might run 14s (or possibly no further than the 1/8th mile cone) too.
I often find it best to actually run the number FIRST, and then talk about how easy it is/was.
A person had better already run some low 10s or even high 9s before they start spouting off on how easy or simple it will be to go mid 9s LOL.
Sounds like you might just be on a path to having the quickest/fastest A6/6L80 equipped Corvette (or any A6 transmissioned car for that matter) on the planet.
Those 345s are good, but ultimately once you start spraying it you're probably going to find that the 15s are almost necessary.
St. Jude Donor '10-'11-'12
The fastest 6L80 trans Vette I know of is this one at 9.55 and 144 mph.
Also stock long block:
Mine was fastest before that for 6L80 trans and stock long block (small cam) :
Good luck with quest. Your car is certainly set up for some excellent times/ mph in the 1/4 mile.
I f you go in the 6s you should be safe to brag all over town that you are the record holder.And then you ll feel fulfilled.Start by hitting 12s and work your way down.
