Ragin Racin Stage 1,2,3,4 "SALE"
Supporting Vendor
Ragin Racin is offering a parts package for all performance levels. All the parts you need to bring your performance up to your desired HP levels. Put a little Rage in your Vette, Remember "If you're not Ragin you're not Racin"!!
Stage 1
Honker CAI
Ragin Racin ported intake and throttle body*
160 stat
$725 Z06 add $100
Stage 2
Honker CAI
160 stat
Long tube headers
$1765 Z06 add $100
Stage 3
Honker CAI
160 stat
Long tube headers
Ragin Racin cam of your choice
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
2 water pump gaskets
Crank seal
2 valve cover gaskets
$2895
Stage 4
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
Ragin Racin ported heads*
head bolts
2 head gaskets
$3850
For details please call 337-278-8397.
* We port your core.
__________________
Randy Leger
337-278-8397
sales@raginracin.com
http://www.raginracin.com
Stage 1
Honker CAI
160 stat
$725 Z06 add $100
Stage 2
Honker CAI
160 stat
Long tube headers
$1765 Z06 add $100
Stage 3
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
$2895
Stage 4
Honker CAI
160 stat
Long tube headers
Pac dual springs
Pac TI retainers
Pac spring locators
Crank bolt
timing cover gasket
Crank seal
head bolts
2 head gaskets
$3850
__________________
Randy Leger
337-278-8397
Supporting Vendor
Cam choices:
LS 1,2,6 Camshafts
Stinger 224/232 .625/.625 113 1800-6800 rpm powerband Exlellent low end torque and midrange power with excellant street manners.
Undertaker 224/232 116 Off idle-6800 rpm power band Stock drivability with a very minor lope. Excellant stealth or blower cam.
LS1 Blower 220/230 114 Off idle to 6800 rpm very nice idle and drivability to maximize performance inr boosted lsx.
Shreader 228/236 113 2400-6800 rpm powerband Excellant midrandge cam with decent drivability. Choppy idle.
Distroyer 232/242 112 2800-6800 rpm power band Great top end power. Some surging at lower rpm's. convertor required.
LS3
Intimidator 224/240 113 1800-6800 powerband excellant low end and with a good top end punch. Real good drivability. Nice choppy cam idle. No convertor needed.
Avenger 228/244 112 2000-6800 rpm powerband Great mid range
and top end power. Choppy idle Convertor required.
LS7
Sleeper 222/242 114 off idle to 6800 rpm powerband Excellant torque Like stock drivability very mild idle.
Stalker 224/246 115 1800-6800 powerband excellant power through out great drivability Choppy idle
Lethal 232/250 113 2400-6800 rpm powerband Excellant med range with a great top end punch. Minor low rpm surging. Nice choppy cam idle
Punisher 236/256 111 2800-6800 rpm powerband Good mid range and excellant top end power Very choppy idle
Striker 240/260 109 3000-7000 rpm powerband Great top end punch very choppy idle
Blower 1 224/248 117 Very efficient with slight cam sound to idle Stock drivabilty
Blower 2 232/256 114 Choppy idle for larger blowers Some surging at lower rpm's
LS9 ZR1
ZfoRce1 224/250 115 nice choppy idle with good drivability
LS3
LS7
LS9 ZR1
