2008 C6 Common Issues Question
Question to other forum members regarding common issues on the 2008 C6 LS3 - vette - I bought mine back in Feb 09 brand new and I picked up the extended warranty on it - got lucky, because turned out I needed it - just checking into common issues - these are the ones I've had happen so far (note: car only has 38k on it)
1. Water pump - out at 12k
2. brake rotors - out at 15k - I used after market to replace them with
3. battery leaked - cause wiring harness to need replacement
4. drivers side door stopped opening correct - electrical issue
5. key fobs went out
6. more recently - harmonic balancer just died
7. ticking in suspension turned out to be right front wheel hub replacement needed -
Now did I just get "unlucky" with mine? I've read about some of these issues being "common" - just wondering if I need to sell my car before the extended runs out on it.
Have had no issues with mine got it in april of 08 new. Also bought the extended coverage .Stored for six months a year due to minnesota winters 8100 miles on it . But always looking and listening for something to go . Stock Ls3 436hp
I've only had my 08 for a year, and I've put about 8K miles on it, but I've not had any problems except for the battery going out in one of the fobs.
2008 coupe, Z51,NPP,manual with 48,000 miles:
1. Replaced end links.
2. New rear diff. (whine).
3. Speaker rattle repair.
4. Cowl trim replacement.
5. A/C temp sensor.
6. One TPS on rear tire.
All repaired under warranty.
Thanks for the reminder Boomer111: DIY fix roof latches, also.
5. A/C temp sensor.
08 here with 24,000 with cowl replacement and end links. Put 4:10 diff. in but that was my choice. Original battery, brakes hardly worn. Oh ya DIY fix for roof latches.
2008 z-51 MN6. purchased at 20k now at 30k miles after 1.2 summers of driving. I have only replaced the battery.
I notice multiple people say they have replaced the "End Links". Im assuming suspension components but What are they and any idea whats causing them to go bad? Thanks
08 Z51
41K miles
On my THIRD nav
Water pump replaced
Climate control module replaced
Gauge cluster replaced
Battery replaced
Front passenger end link needs to be replaced. (Havent done this yet)
Still love the car..
41K miles
On my THIRD nav
Water pump replaced
Battery replaced
I bought my 2008 coupe in December of 2010 w/4800 miles on the odo. GM VIS report showed that the only repair the PO had done was a battery replaced under warranty at 4700 miles a month before he traded it in @ the Cadillac dealer where I bought it. The car now has 14,500 miles on it and my only repairs have been a rumbling diff (gear oil replaced w/proper GM stuff by a dealer) and the replacement of both FOB batteries (odd electrical things involving the doors, seat/steering wheel memory, etc.). Other than that, it has been bullet proof (and great fun, even in rush hour traffic!!).
Enjoy,
akriggm
Enjoy,
akriggm
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I think you've been unlucky. Mine I got new and it's an early production one from 8/07. Now, 35K miles. New batt. just because I started worrying about it, not because it needed it. And gas pedal sensor(s) went out last June (replaced under warranty out of town on trip). Also, rear diff fluid changed out with newer "model" from GM. Knock on wood, none of your other issues.
My 2008 baby bought new - now with 78K miles:
1. Broken valve spring at 24K miles, which MELTED the intake manifold...
2. Terrible valve knocking started once every few months at 60K miles (possibly from broken valve spring)...BARTON BIRKS in Newburgh, NY went to bat for me with GM and got approval to have both heads rebuilt - THANK GOD - and the problem has finally been repaired. Work was super professional!! [I am super critical]. I love that dealership and the service manager! I never ever ever said that before about any service guy.
3. Reoccurring problem with TPS - that was finally fixed with new tire monitor RECEIVER. Except I get the RIGHT REAR sensor not transmitting every month or so...which resets itself overnight.
4. Oh yes...and let's not forget the FLYING ROOF CLUB which I was a platinum member...which I finally fixed with a thin chain attached to the drivers latch - that drops down and hangs right in my face - reminding me to latch that fly away roof! My Porsche 944 has a failsafe design that allows me to drive the car without latching the roof, with no way the roof can fly off. Since I had 2 Porsche 944s for 30 years!!!, I got used to not having to latch it immediately.
4. HVAC display panel was replaced.
5. Driver seat leather replaced - and seat cushion foam replaced.
6. Entry key receiver module was changed.
7. Ticking in rear differential...I replaced the fluid myself with recommended GM fluid.
8. After 75K miles, I am ready to install new AC DELCO ceramic brake pads all around.
Oh, and my clear bra - installed by me when the car was new - was SO worth it.
After 70K miles, I think the Vette is finally broken in. It's a great sports car. Hugely better handling than my Porsche 944. I mean the Vette seems like it will never ever skid. All the above except for 7 & 8 were under warranty. Was it all worth it? You bet it was!
This car, and it's thick paint is so unbelievable. If you're thinking about buying a Corvette...let me reassure you...this is one hell of a sports car.
Received 2,051 Likes
St. Jude Donor '13
We love our 2009, but it too has had a lot of problems. I'm too lazy to look up the details, but:
First year: 5 warranty repairs
Second year: 7 warranty repairs
Third year: looks like this one will be 5 warranty repairs.
None of the problems are related to the high performance of the car, just ordinary cheapsh!t parts that fail in normal service.
Our 2009 is worse than our previous 2006, and the 2006 was worse than the previous 2001.
There's a reason people started buying Japansese cars...
Received 2,061 Likes
With this thread title there will be people posting with problems, but the vast majority of people who haven't had problems won't bother.
I've been fairly trouble free for just over 100K. I don't count things that are normal maintenance items like batteries, brakes, and light bulbs or things that I damaged. So that leaves me with just two alternators and a glove box latch as problems.
I think the key is to let your car know right from day 1, who the boss is and how you intend to drive her. I put 5500 miles on in the first 30 days and drove most of it in rain, snow, in mud, on gravel roads, and did a few burnouts and high speed runs, before I introduced her to her home garage and gave her the second bath.
Note to Mike's LS3: The only "redesign" on the end links was to change the tool needed for installation. The interior part that is the cause of the noise did not change.
My 08 with approx 36k:
Oil level sensor went out a few months after I bought the car
Battery only lasted about a year
Hatch lift cylinders lasted about 3 years. hat suprised me a little.
End links - went through 2 sets, including one set of expensive LG ends. The third set seems to be lasting, but I stopped driving on one really bad road whcih I think was causing accelerated wear
My drivers door is acting up a little. I assumed my FOB battery was getting weak, but maybe not after seeing others reporting trouble.
My car has never been to the dealer. My problems have been minor enogh that I'd rather avoid trips to the dealer and just pay for th parts and fix it myself.
