ABS Control Module
ABS Control Module
ABS Control Module. Does any one know if a used ABS control module can be installed & programed so it will work in a different car.
The 2005-2008 have an ABS made by Delphi. You need the compatible parts - EBCM, BPMV, and wheel hubs with the Delphi wheel speed sensors.
In 2009 they switched to ABS units made by Bosch.
So.....you should be able to swap units from a 2005-2008 to another C6 in that model year range, or from a 2009+ into another 2009 or newer C6.
Bob
I believe some of them can be. Here is a thread on how to add launch control to your 09.
http://forums.corvetteforum.com/c6-t...-corvette.html
What model year C6 do you have??? There's nothing in your profile that shows anything about you or your C6.
Bob
Bob
Sr.Random input generator
If it's a 2009+ model, I have the control module available:
http://forums.corvetteforum.com/c6-p...-cylinder.html
