Old 03-02-2015, 08:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
[Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
Old 07-28-2012, 12:53 PM
JUIC3D
JUIC3D's Avatar
St. Jude Donor '11-'12-'13-'14
Default [Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
Hi CF brethren,
Upon a routine oil chance I discovered a mysterious metal piece in my oil pan that was too large to fit through the oil drain hole. Before discovering this piece the car ran fine, had no issues, no smoke, and was(still is) a regular attendee at the dragstrip.
I polled the audience and thanks to glenB, it was determined that the most likely piece was the spring from the tensioner and the oil pan would need to be pulled to remove the broken part.
I did this on a 2 post lift but it could be done on jack stands if you had a smaller floor stand.
Here is my original thread about the mysterious object
http://forums.corvetteforum.com/c6-t...s-enclosed.htm
1) Raise vehicle
2) Remove front wheels
2.5) Drain motor oil
3) Disconnect shocks at LOWER mounting point (2x 13mm nuts/bolts)
4) Unbolt upper A-arms and be sure to keep a note of what shims are in place(if applicable) (4x 15mm bolts)
5) Disconnect brake line mounting point and wire harness from each side of the cradle (2x 10mm shorty bolts)
5.5) Remove front leaf spring so you have access to the crank pulley. (4x 15mm bolts)
6) We used this style jack under the crank pulley to support the motor
http://www.harborfreight.com/media/c...mage_11255.jpg
7) Unbolt lower motor mount bolts
8) Support motor with above jack
9) Loosen cradle bolts(4) to the very bottom of their threads. If you need more clearance, remove the rear bolts to allow cradle to flex. Keep the front bolts with at least a few threads so you don't have to line everything back up.
10) Once cradle is lowered, you can slowly raise the motor approximately 1.5 inches.
11) With the cradle lowered and the engine raised, you have about 2.5" of total clearance which is plenty to get the job done. There was plenty of room to remove all the oil pan bolts and unbolt the oil cooler lines and other small brackets
12) Carefully remove oil pan. The pickup tube runs the length of the motor but is not obtrusive at all.
13) Reverse the steps and you're done.
13a) Cradle bolts are 81 ft lbs
13) Bigger oil pan bolts call for 18ft lbs, the 2 smaller ones in the rear(the longer ones) call for 106 inch lbs(~9ft lbs)
14) Important: There are 2 bolts from the bellhousing that are secured into the oil pan. With the weight of the motor on the crank pulley, there will be very slight separation and you'll need to wait until the very end to secure these bolts as you don't want to misalign the oil pan and risk it leaking. Torque on these bolts is 37 ft lbs.
Make sure you clean off the gasket so it has a nice surface to seal against. The gasket is riveted onto the oil pan which I thought was odd so I just gently lifted up and cleaned all the residual oil so everything sealed up nice and tight.
Here are some pictures
The mysterious piece
Looking up at the tensioner from below. The only thing left is nub and it just spins around, there's nothing left
/Broken tensioner
Success!
Old 07-28-2012, 12:58 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Great DIY post Justin. Worthy of the DIY sticky!
Old 07-28-2012, 01:09 PM
taken19
Track Junky
taken19's Avatar
100% Sticky, sticky, sticky...
Old 07-28-2012, 01:31 PM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
I agree, this should be a sticky. Good post!
Old 07-28-2012, 07:20 PM
Craigster05
Support Corvetteforum!
Craigster05's Avatar
St. Jude Donor '07-'08-'09-'11-'12
Awesome post..sticky for sure...so glad you were able to figure it out and get to it before any further damage occurred.
Thanks for sharing.
Old 07-28-2012, 07:25 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Justin probably worth noting that per GlenB, the tensioner was used with the loose factory chain with asymmetrical gear teeth starting in 08...I hadn't heard that before but it makes sense.
I'm going to guess your super tight c5r chain you put in the car when you installed the cam couldn't use the tensioner and in fact broke it.
Wouldn't want the ls3 folks to think the sky is falling.
Old 07-28-2012, 07:40 PM
taken19
Track Junky
taken19's Avatar
Good point Joe. I know that cloyes makes a timing chain set that is highly regarded in the racing world. It has an extra tooth to take up any and all slack in the chain from what I heard. That's what Schwanke recommended to me when they quoted me a true road Race engine. I wonder if anybody out there has experience with that setup.
Justin, I think I will be using this post as soon as I feel like getting back into the motor for an Avaid oil pan baffle. Thanks again for the thread!
Old 07-28-2012, 11:03 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Not sure about an extra tooth, not an engineer but I would think that would throw off the sync between the crank and cam since they use the same chain as the C5R, but I could be wrong.
Anyway, when talking to the Cloyes people at the PRI they told me the setup is as tight as the Gen 2 motors. I'll be finding out soon since I'll be doing a cam and will be using their setup. I just have to get off my lazy a$$ and just do it, maybe Thanksgiving weekend sounds like a plan.
Old 07-28-2012, 11:21 PM
taken19
Track Junky
taken19's Avatar
Glen, I could be talking out of my butt, but I thought I heard that. Either way, they told me that it's the set to buy. I thought is may throw off the timing as well, but the bottom dollar figure of their motor made me forget the details with ease...
Do their setup before I swap cams in my car so I can live vicariously through you for a cople months, lol!
Old 07-28-2012, 11:46 PM
JUIC3D
JUIC3D's Avatar
FWIW, I ran the car tonight and made 5 passes with 4 of them being on the bottle with no issues. Car ran strong and performed flawlessly with essentially no tensioner. I'll pull it apart next week to get the dampener in place. I drove home with the a/c on and the stereo blasting. I love my car
Old 07-29-2012, 12:02 AM
taken19
Track Junky
taken19's Avatar
Good to hear man!
Old 07-29-2012, 12:19 AM
JUIC3D
JUIC3D's Avatar
Here's a fun clip from tonight.
Me versus my buddies lightly modded ZR1. Pulley, long tubes, tune...
I was on motor, no nitrous on this pass.
Old 07-29-2012, 12:22 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
^^^nice clip....you knew where to mount that camera huh!
Old 07-29-2012, 12:24 AM
JUIC3D
JUIC3D's Avatar
He was on street tires..I was pretty confident I'd take him. He even said something when I was mounting the camera.."feeling good about this race are we?" I just smiled
Old 07-29-2012, 01:44 AM
taken19
Track Junky
taken19's Avatar
Justin... King of the strip, and the str....... er, Mexico!
ZR1, huh? NICE!
Ur the man!
Old 07-29-2012, 03:12 AM
krackenvette
krackenvette's Avatar
Nice run. Put some feathers or cotton over the mic, and it will help with the wind noise..
Old 07-29-2012, 06:37 AM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
added
To [Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
Old 07-29-2012, 09:20 AM
0Tampa Tuning
Former Vendor
Tampa Tuning's Avatar
St. Jude Donor '12
I bet you picked up 2/10th just from the weight reduction
Nice work after the inital WTF is that lol
Old 07-29-2012, 10:27 AM
JUIC3D
JUIC3D's Avatar
Thanks. I don't want to muddy up this DIY sticky thread but thanks for the compliments.
Old 07-29-2012, 12:43 PM
corvettej
corvettej's Avatar
St. Jude Donor '13-'14-'15-'16-'17-‘18-‘19-'20-'21-'22-'23-'24
That was the same thing that happen on my 07 ls2 when I took it to the dealer for oil pan gasket seep, when they drop the oil pan they found the metal piece of the tensioner, they replaced it under the powertrain warranty and send the parts to GM, they caught it 4 months before the warranty was up, my warranty ended 17th of July 12.
Quick Reply: [Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
