Lowering bolt install C6 how to (with pics)
The corvettemods bolts do not have "delrin" made caps. They are just rubber hence the reason they tear up so easily. Also...grease will only advance the issue with lowering/cut bolts due to bringing in all that dirt, rocks, grime, etc. Imagine all that crap smacking that rubber against metal...it's no wonder they turn to garbage.
I am reading all these threads about after market lower bolts. I get the idea of the improved look/stance and so I am not critiquing anyone's mods. But I cannot believe that cars so lowered don't scrape on every dip on the road? I guess I am the only one that actually raised the ride height because I was sick of the scraping.
Reading other threads, the consensus is that any major change in ride height dictates that alignment should be checked.
The only thing low enough on a C6 that will scrape while driving is the air dam, and that is made to scrape. The subframe and all that important stuff actually sits pretty high relative to the body. Even lowered, the air dam is about the only thing that takes any real abuse. Raising the car from stock height not only degraded your handling, but I bet it also looks terrible.
Be sure and tell that to all the people that have replaced the lower radiator support.
Just an update. These lowering bolts are complete garbage. I have already gone through my 2nd set on the rear. Yes, I used plenty of heavy duty grease. My car is not a daily driver. I got about 1k miles out of each set in the rear before that delrin pad was completely disintegrated, like it's not even there, just metal on metal now. Real easy to tell because it starts making an awful noise over the smallest cracks and you can actually feel the metal to metal contact. I will be cutting down the pad on the stock bolts this weekend for the rears and will see how those hold up. That rubber pad on the stock ones seems much more durable than that delrin crap on the corvette mods ones. Don't waste your money on them unless your car is a trailer queen show car, seriously.
Has anyone cut about an inch off the bottom of the air dam to stop some of the scraping? If so, any loss of flow for cooling? I scrape every time I back out of the driveway and lowering the stock setting, even without citing bushing only made it worse.
That air dam is pliable and flexible, therefore made to scrape. It does nothing for engine cooling, for the C6 is 100% front feeder. The outer plastic pieces of the air dam help push air into the brake ducts. I would not recommend cutting any of that stuff and live with the scrapes...just part of being lowered.
The caution paint scuffs marks are a tell tale sign.
I can see why the support can get broken if an owner can't judge distance when parking.
At 100.00 I am good with randomly replacing the air dam.
I gave up worrying about it dragging the ground.
What I have noticed is I don't hear that dam scraping sound every time I back out of my driveway any more. Pretty simple, blue painters tape along the dam, a flexible 1" wide Ruler to make a mark, and the old jigsaw. Cleaned it up with a belt sander. Looks good, and no dam noise!
#33
I went ahead and cut 1" off the air dam and have seen no side effects as far as cooling, either brakes or radiator goes. I drive in a lot of stop and go on the freeways of houston, 45 miles each way every day.
#34
MiltIV, for cutting down the stock bushings I'll recommend a super-sharp serrated blade (like on a multi-tool) & WD40 to ease/lubricate the cutting. I tried this when trimming the bottoms of my stock rear bushings & the serrated blade/wd40 combo cut the rubber quite cleanly. I'll also recommend cutting only the bottom-most rib off the rears & then you won't need to cut the stock fronts...Let us know how it goes.
#36
Hi everyone -
I recently bought my 2011 GS and love it. The first mod that I wanted to do was go ahead and lower the car. I previously owned a Z51, went to the same guy, same shop who cut the stock bolts down half way as I was happy with the ride height and didnt have any issues.
Fast forward, I took my 2011 GS as we went throgh the same procedure. Once I got home I realized that I had grease inside my rear drivers wheel coming from my CV boot. I didnt think that this would be due to lowering the car, however I went ahead and took it the dealer.
The master mechanic there explained that the boot ruptured because of the way the car was lowered. Any of you guys experience this?? If so please reply or PM me and let me know if this would actually be the case and what you did about it,
Thanks in advance!
Thanks in advance!
#38
I don't see how the boot ruptured because of the bolts? Those boots are made to move up and down, and there are plenty of guys with lowered C6s without the issue. Since its a dealer, it sounds like they are saying the cut bushings caused the tear so that it would not be covered under warranty and therefore will be money out of your pocket.
#39
Life Starts at 120 mph
NCM Lifetime Member
Great Tread, very informative
I recently purchased a 2010 GS, I also track my car 8-10 days a year with NASA NE. From everyone's advice, which is great, it sounds like I will just lower my GS, with no cutting, no mods, on the factory bolts. Screw them in and let it ride.
The question I have, does anyone here track theirs and do you have any tips with regard to the lowering.
Thanks in advance
Boxcar
Thanks in advance
Boxcar
