Hard to get out park
I have 05 I just bought, leaving work could not get out of park for several minutes. Looked on forum c5 said to disconnect shift solenoid, would that work for the c6 and how do get the solenoid.
In most cases when this happens a new shifter is in order. There are tons of threads about it. Search "stuck in park". One way around it is put car in accessory mode. You should then be able to shift to neutral and start the car.
Jeff
http://forums.corvetteforum.com/c6-t...ght=stuck+park
Thanks for the information, I tried the acc mode and that worked so I feel better about not getting stuck. I pushed the shifter forward and that also worked, I can hear the soleniod operating. May pull console if it gets worse.
