ProSport gauge install question
I installed a set of ProSport Gauges (Wideband, Fuel Pressure, boost)in my 08 C6.
They are daisy chained per the instructions and the lighting is wired for white illumination daytime and blue illumination for night operation.
I wired Red to 12v constant power from engine bay fuse block.
White to accessory power when ignition is on.
The Orange is supposed to be wired to a 12v head light switch.
I tried the dimmer wire (brown lead) per a corvette vendors instructions from this forum.
The fuel pressure will not come on when the lights are off (daytime) but works fine if the lights are on but only illuminates white.
The other two gauges work fine no issues.
What specific color and location wire in the under dash 08 C6 harness is 12v power when head lights are on? How have others wired these gauges? Any help is appreciated.
