How to replace key FOB battery?
Old 01-15-2013, 06:18 PM
billythekid310
billythekid310's Avatar
Default How to replace key FOB battery?
One of mine went dead and I would like to replace the battery if it is possible? Also how do you take apart the FOB?
Old 01-15-2013, 06:28 PM
Colovette
Support Corvetteforum!
Colovette's Avatar
Replaced both of mine for my '05. I first removed the steel key ring on each and then very carefully pried the two halves of each fob apart. After the battery is changed, the two halves snap back together.
Old 01-15-2013, 06:40 PM
billythekid310
Mine is a 2009 Corvette I forgot to mention this. Does this make a difference? So it just snaps apart and then back together?
Thanks!
To How to replace key FOB battery?
Quick Reply: How to replace key FOB battery?
