Transmission cooler fitting issue.
About finished up with trans cooler install on my 2008 A6 car and having a pain in the *** issue with one of the fittings.
Found this member post this info on here a few times on the list of fittings for the install.
http://forums.corvetteforum.com/1577751628-post9.html
I have everything installed and mounted and the one issue i have having is with the 16x1.5 adapter fittings sealing with this dorman fittings
http://www.summitracing.com/parts/rus-640830
http://www.summitracing.com/parts/rnb-800-605
Everything else is leak free and fits great but when mating these two together no matter what they do it's leak. I'm not sure if it's supposed to have a o-ring in the russell fitting, because mine does not have one.
Ill feeling like if it had a o-ring when you tighten them down it would help seal it up. I'm calling summit tomorrow where i got the fittings and trying to find out if I'm missing a piece or what.
Any help would be nice or someone else who has used these might know.
Received 2,061 Likes
After trying to get fittings to match up to everything, I went to a scrapyard and got a short piece of the tubing that snaps into the radiator. I put a bulge in the end I cut off and slipped my hose to the cooler on, then double clamped it.
It never leaked on me. I applied some teflon tape to the Dorman 800-605 and tightened it down good. Make sure you're getting the correct Dorman fitting as some have different mating surfaces and if it's different - it won't seat inside the Russell fitting like it should and it will leak. Could it have been packaged wrong (800-606)?
Yea i ended up taking the fittings off and sliding the hose over the factory bulge in the line and clamping it and having no issues now.
http://www.dormanproducts.com/p-8572-800-605.aspx
I called summit and they said the russell and dorman fitting are not meant to mate properly.
Did you dorman fitting look like that?
I also asked if the russell fitting was supposed to have a o-ring and they said "no the male end of the fitting you are threading into the female end of the russell should be oringed"
This is the fitting i got
