Rear tire setup
Rear tire setup
What do you set your rear tire toe and camber alignment to for dragging and street. I measured rear camber at just under -1° but a temp measurement shows the inside of the tire tread running 10-15° hotter than the outside. Gonna try 0 camber and toe and see what it reads and drives.
I run a -1.2 rear camber to help keep it from stepping out in the turns. It was -1.4 but I found it really hurt my straightline acceleration so the -1.2 became a decent compromise.
