c6 z06 caliper mounting bolts
I am upgrading my old corvette(1962 resto) to c6 z06 brake calipers (strickly for looks). Not looking for performance or anything else. I need the 2 mounting bolts per caliper. I think they are part #14084051?
I think they are 14m coarse thread 2" maybe 1 3/4"?
Any help would be great.
Thanks guys
Thanks guys
the part number 14084051 you listed is shown as...
item #35 in the pic with description of...
BOLT. Wheel Brake Cylinder/Caliper
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BOOT-BRACKET-CALIPER-CALIPER KIT-DUCT-HARDWARE KIT-NUT-PIN-SCOOP-SEAL-WASHER, Wheel Brake Cylinder/Caliper. For: Y (1997-2004) (2001 - 2004). Required: 04
item #19 is the same pn and same desc as item #35
sending you a PM with part pic and pn and desc and stuff
fyi.. look at a 2006 here is the full description, note years valid for..
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BRACKET-BUSHING-CALIPER-CALIPER KIT-PIN-SPRING-WASHER, Wheel Brake Cylinder/Caliper. For: Y (2004-2009) (2004 - 2009). Required: 04
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BRACKET-BUSHING-CALIPER-CALIPER KIT-DEFLECTOR-DUCT-PIN-PIN KIT-SCOOP-SPRING-VALVE KIT-WASHER, Wheel Brake Cylinder/Caliper. For: Y (2005-2008) (2005 - 2012). Required: 04
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BRACKET-BUSHING-CALIPER-CALIPER KIT-DEFLECTOR-DUCT-PIN-PIN KIT-SCOOP-SPRING-VALVE KIT-WASHER, Wheel Brake Cylinder/Caliper. For: Y SOFT RIDE SUSP(FE1),RIDE & HANDLING SUSP(FE2) (2011-2012) (2005 - 2012). Required: 04
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BRACKET-BUSHING-CALIPER-CALIPER KIT-DEFLECTOR-DUCT-PIN-PIN KIT-SCOOP-SPRING-VALVE KIT-WASHER, Wheel Brake Cylinder/Caliper. For: Y SOFT RIDE SUSP(FE1),RIDE & HANDLING SUSP(FE2),SPORT SUSP(FE3),SPECIAL SUSP(FE4) (2009-2010) (2005 - 2012). Required: 04
BOLT,FRT BRK CLPR(M14X2X47). BOLT-BRACKET-BUSHING-CALIPER-CALIPER KIT-DEFLECTOR-DUCT-PIN-PIN KIT-SCOOP-SPRING-VALVE KIT-WASHER, Wheel Brake Cylinder/Caliper. For: Y SPORT SUSP(FE3) (2011-2012) (2005 - 2012). Required: 04
