Service Traction Control ,active handling,etc, etc-7 dealer visits so far
I have a 2012 Centenniel edition GS with 6 spd and 9000 niles that starting displaying the service traction, active handling etc codes after 2000 miles. I've made 7 visits to date to the dealer with replacement of battery, and BCM most recently. Nothing works. Unfortunately it seems a common complaint with C6's. The car displays the codes:
U0100,U0122, U0140. U2100, U2107, U2108, U2105. These apparently are all lost communication codes but no codes pointing to a defective system or part. Car still warrantied and I'm going back for the 7th or eigth time (I've lost count). The messages are: service ride control, service traction system, shocks inoperative, speed limited to 80 mph, service vehicle soon, and lately, low fuel as the gas gauge drops to 0 and resets itself after about 2-3 minuteas of driving. The fuel gauge deal occurs about every third time. Sometimes the service ABS code is thrown.There's never a change in the driveability of the car or activation of the ABS system as some people have seen. The dealer is in contact every time with GM tech support they say, but nothing seems to work. It occurs now about once daily to every other day. Tires and inflation are all good back and front. I'm sure this is redundant for many on the forum but just trying to fish for any new ideas or new eyes on the problem. Thanks in advance for any help.
Dave M.
Dave M.
i've researched this same problem that i had both early last year and again early this year. plus researching for others.
i can only say two things...
1) you are lucky to have full warrenty
2) without full testing equipment (tech2) that they have , your would have to start throwing parts on.
this is what i came up with that can cause the error(s). in your case it seems worse, as usually a C code and it's sub C codes point to the root cause.
List of items that cause the error are.....
Wheel Speed Sensors
Brake Pedal Position Sensor
Brake Fluid Pressure Sensor
Steering Wheel Position Sensor
Yaw Rate Sensor
Lateral Accelerameter Sensor
or... bad contacts/connectors/wiring for one of the above
i doubt seriously the above is all inclusive. in my case, oddly enough, mine throws P0106 code, map sensor. then sah/tc begins. the car gets worse. finally reaching a point where it snorts, coughs, jerks, belches, dies. restarting the problem disappears entirely for , well, 1 year last time... lol
warrenty is your best friend at this point!!!
good luck
Wheel Speed Sensors
Yaw Rate Sensor
good luck
When you start getting messages that are not related to one another (like in this case the fuel gauge dropping and service engine soon should have nothing to do with traction control and AH) I would suspect a voltage problem causing everything. I would recheck battery and all connections including the positive connection at the starter.
If you have been back 7 times, then you have qualified under the lemon law in almost any state...I wouldn't mess with it at this point. Lemon it and get a different one.
Been there, done that, go the T shirt and the hat to prove it.
But before the lemon law, talk to them about a buy back. Get the district rep to come to the dealership, and tell him that you want to make the best of a bad situation.
Try to avoid the lemon law if you can, you should win, but it IS a lot of work. Been there, done that too, on a different vehicle. Arbitration is very time consuming, and most lemon laws get to that point.
They should work with you, they did for me, on a similar problem ridden 2008 that I had, for a buy back.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
There have been some good suggestions here like testing all the ground/charging connections (alternator wasn't mentioned but should be included) and the fact that if there is something wrong they should have found it by now. They haven't.
Fortunately, you have several choices: keep chasing it at the same place; find another; keep your warranty in effect; lemon it.
You may not qualify under lemon laws if you keep jacking around with it; I'd find out now whether you do or don't qualify.
Good luck and tell us how it all turns out.
Received 8,924 Likes
Bill
And if you're contemplating the lemon law as an option, check your state laws right away because there're limitations in both mileage and time. In some places is 1 year and 10K miles or less. Other states are much more consumer friendly. Good luck, and please keep us posted.
Interesting point about the hard hit. Bought the car in Tampa and drove it home to Alabama . No problem with the tc warning at all. But I hit a small pothole while making a uturn apparently enought to scrape a place on the outside of the right rear wheel and scrape the tire.
The tv/ah warning occurred a week or 2 later. I thought about the wheel speed sensor but apparently no tech2 codes from there.
Dave M.
Dave M.
Could you please private message me your information (name, number, address, VIN, current mileage, and involved dealership) so I can check into your situation?
Evan, Chevrolet Customer Service
Result of 7th vsist to dealer with 2012 Centenniel edition C6- Replacement of the EBCM after a "C" code kicked out indicating an actual physical part rather than the usual "U" codes indicating lost communication between units. No difference. Within 24 hours. TC
and AH and "low fuel" messages kicked out. Also, the same day, it took 5 pushes on the starter button before the car would start. Moving on to visit number 8 or is it seven or 9? I'm not sure. I've lost count.
Check you state laws. Here in Florida, after three times back to the Stealership for the same problem, the Lemon Law takes effect.
I feel for you problem brother. I suffered through them also. The SAH/STC is the Achillies Heal of these cars. After a few months of experiencing them, I was seriously considering getting a old Hot Rod without any computers.
My C6 is displaying the Service Active Handling message. Absolutely zero codes show up using a Tech 2. Car performs with no issues. The battery is new. The little plastic "comb" to better hold the steering column wiring harness, which is what the Service Active Handling Recall offers was installed by the dealer.
Pressing TC button briefly turns TC on or off, and pressing and holding the TC button does nothing other than turning TC on or off.
Any suggestions or ideas?
One thing to remember is EBCM codes reset when the engine is turned off so you have to wait until the service message reappears and then use the Tech 2 to scan for codes without turning off the engine.
Bill
If you cant find C0561 then the code reader device/person is at fault.
http://forums.corvetteforum.com/test...post1584857029
If SAH message is on , you have code C0561 stored. Its a default code that just means... "I was told to turn on SAH so i did" , other codes will direct you to problem.
Bill
