Quick question about C6's exhaust are auto and manual different sounding?
Im in the market for a used C6, probably a regular vette most likely and have been considering to get a full Corsa Exhaust, then doing long tube headers and Cams. My question though is with the corvette exhaust system if I Just start off with the exhaust for example is there a difference between the sound of the Automatic and Manual Exhaust. It never hit me that the exhaust sound would change just because of differences of the Transmission. Im asking because when I looked into the Description and Features it says "Not acoustically recommended for Automatic Transmissions" On Corsa's website for the Xtreme Axle-back Dual Exhaust systems with Twin 4" Pro-Series Tips http://corsaperformance.com/product_...px?product=892
The only difference I could think of is the small delay when engaging and disengaging the Clutch and shifting to another gear. What else changes. I know that no two cars will sound alike whether you put a auto next to a auto or manual to manual, but how does putting a Auto next to a Manual change the sound? Also couldn't a Auto tranny in manual mode, Mask its self as a Manual sounding just by Taking your foot off the gas and shifting and reapplying the throttle? So it shouldn't really make a difference in that regard. So what gives?? Thanks Guys!!
Manual drivers tend to keep rpm higher; that's all. You can use an auto in the 'S' mode and use lower gears with the paddles too. But if you lug the engine, it can drone with an auto or manual transmission, since it's rpm related. If you don't want any drone, just buy the 'sport' system, which is loud enough for most.
Thank You I'll just do that!
I am going to find the answer to this question as soon as I am financially able to. I want the Xtremes on my 07 A6. I do not believe they will drone that badly, but Corsa has a very discerning customer and wanted to possibly offer that warning to protect their reputation.
Also of note, from what I have read on here, if you have heard the NPP mufflers open, the Xtremes are only a touch louder. Many say they are slightly louder than the stock NPP valves closed exhaust at low RPMs but sound positively evil upon juicing it.
Keep in mind the demographic of the car owners as well. The younger crowd does not mind some drone and noise while the older owners prefer quieter exhausts with some bite upon throttle, which I believe the Sports are. I have heard of one user on here who believed the reviews of the Xtremes and was disappointed after he bought the Sports and found they were similar in dB levels to the stock exhaust until RPMs were brought up.
My suggestion would be to see if you can find any local owners or clubs in your area and see if any members have them. Post in the regional forums.
Received 2,061 Likes
Dual mode works for me.
I've noticed some aftermarket axle back systems list two different mufflers for auto and manual transmissioned cars. Dimensionally they are identical, but they recognize the drone syndrome in the automatics and apparently adjust the build specs respectively.
Since the engine speed is what creates the drone, neither the auto or manual can avoid passing through that range.
The auto is louder all they way through the rpm range. I had corsa sports on my 2011
A6 and when I traded for the 12 the I had dealer put my sports on the 12 6m and the interior noise is about 25% more quiet driving and 50% at idle with the stick. That is apples to apples as you can get...
