LS2 + FAST 102 + Halltech Superbee problems
Old 03-16-2013, 05:12 PM
EyeMaster
EyeMaster's Avatar
Default LS2 + FAST 102 + Halltech Superbee problems
I need advice. I've been installing the Fast 102 and Halltech superbee in my garage, but it seems the superbee doesn't fit. If I had the sensor in the halltech air intake, there would be no problem, but I have the big sensor that is part of the stock LS2 motor. Or maybe it's the Fast that is pushing everything forward too much?
Seems I need 1 more inch between the cold air intake and the throttle body.
Also, the Halltech filter takes up the whole space in front of the radiator. I didn't take the shroud off the radiator, I don't believe I'm supposed to. The filter is pressing against the front frame of the car.
I'll post a pic shortly.
Old 03-16-2013, 05:32 PM
SUB VETTE
SUBVETTE
Support Corvetteforum!
SUB VETTE's Avatar
Shouldn't be a problem with the FAST 102. I have a FAST on my LS2 with a K&N intake and everything fit properly.
Quick Reply: LS2 + FAST 102 + Halltech Superbee problems
