whats the best ls2 stroker kit?
whats the best stroker kit for a ls2 and how much power will it make and whats the cost for everything?
I'm going to be running a procharger on the motor.
I used the Eagle kit, not the best but on year 5 with no problems. I had it ported\port matched with a Fast and AFR heads.
Built it myself in the garage. Installed in a Silverado, running 11.1 @ 120mph
My 383 also has the Eagle kit, on year 6 with it too. No problems. It ran 11k with the clutch included (from a shop in Florida) but no porting or port matching. Also has Fast and AFR heads, NA - 11:1 Comp. With a mild cam, runs 10.6 @ 132mph.
My buddy just finished his Procharger 402 (low compression). The motor ran about the same amount. I will check on which stroker kit.
No ET's yet as the power killed his new built A6 tranny. Being repaired now.
Motor Pic of 402. I'm sure he would answer any questions you might have and save you some leg work. He had the bottom end put together by local race shop, then we did the rest.
Goyabean321 (04-26-2019)
