question about corvette C6 header and O2 sensor
Good evening.
So i installed the dynatech headers on my C6 .. how ever i didnt find the front O2 sensor port ... only the rear ones which are locted at the end of the headers
Currently the front o2 sensor is not connected .. can i use an extension and connect the front ones in the rear ports?
Or are the ports there for the front o2 sensor ???
The rear ones which have been located behind the catalytic converters. Installed headers W/O aftermarket catalytic converter
Thanx
Thanx
The O2's in the header collector are for the front 02's..The rear 02's should be in your X-pipe....
http://www.dynatechheaders.com/instr..._C6_05to10.pdf
Hope that helps!!
Charles
Hope that helps!!
Charles
Good evening.
Thanx
Thanx
The ports mentioned above ARE the front O2 ports.
The rear O2 ports are in the next section of pipes.
Front is before the catalytic convertors, rear is after the catalytic convertors (or anyplace after the front ports) .
"..only the rear ones which are located at the end of the headers"
