2008 FOB doesn't work
I have an '08 coupe, FOB #1 works but #2 doesn't. I have replaced the batteries it worked once after I replaced it and now it doesn't work again.
Any suggestions.
Any suggestions.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
I inserted in glove box and it worked. I removed it then tried starting and it didn't work. When you try to unlock it from the FOB it doesn't work.
Thanks for your quick response.
Those symptoms are certainly consistent with a fob that is not getting power. Could be dead or low fob battery or battery installed incorrectly...take a look at the DIY at the beginning of C6 general.
