no xm1 or xm2
no xm1 or xm2
hello all,
I just purchased a 2005 C6 and sold the C5. I have read the write ups about not getting xm1 or xm2 and tried disconnecting at the xm module at the wheel wheel and still no xm1 or xm2, I have also read to disconnect and reconnect the Pal connections. only thing is where is that?
Thanks in advance
Mike
Thanks in advance
Mike
does the car have a PAL adapter? check in the passenger side rear cubby hole, that is where the cd player would go. if it is not there you will need to pull the console and then the radio.
