Cloyes Hex-a-just timing sets
Old 05-08-2013, 12:36 PM
SDPC
Premium Supporting Vendor
SDPC's Avatar
Default Cloyes Hex-a-just timing sets
If you want a timing set from one of the best companies to ever make them AND you want to properly dial in your cam timing like we should all be doing when installing a cam, this deal is for you.
This is the Cloyes Hex-a-just timing set for the LS1. Easily advance or retard your cam by 6 degrees either direction without removing the camshaft or crankshaft timing set gears.
This is the timing set most of us want (and NEED) without the usual price tag involved. Genuine Cloyes timing set, new in the original packaging.
$115.20 plus the ride.
https://sdparts.com/details/cloyes-gear/clo9-3153a
This picture is simply to show you how it is adjusted:
__________________
800-456-0211 / PM /E-mail Facebook AIM or Yahoo: JSSDPC
SDPC since 1929 thanks to you guys! WHIPPLE Superchargers, Procharger, Magnuson,
Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, Yella Terra, HPTuners, 7.400" pushrod set (other lengths available)
Quick Reply: Cloyes Hex-a-just timing sets
